    Aug 16, 2019 @ 20:06
    Alex Skrypnyk
    ImageProcessor Mask doesn't work after upgrade to 7.15.1
    Hello our community
    We've recently have been upgraded the Umbraco 7.6 site to Umbraco 7.15.1 and everything works fine, except ImageProcessor Mask feature. We see a black mask instead of transparent. Help, please :)
    Thanks, Alex
  • Ronald Barendse 39 posts 218 karma points hq c-trib
    Aug 18, 2019 @ 11:35
    Ronald Barendse
    Hi Alex! Are the ImageProcessor packages and/or configuration also updated? The Umbraco version itself shouldn't matter, as long as the generated crop URLs are identical...
    There are some related issues with blacked out images regarding the PostProcessor: https://github.com/JimBobSquarePants/ImageProcessor/issues/713. Are you using the PostProcessor or running on Azure?
    Aug 21, 2019 @ 16:39
    Alex Skrypnyk
    Hi Ronald,
    Thanks for the answer, I didn't upgrade image processor package separately, I just updated Umbraco, so maybe it's the case.
    But then, why it works locally and doesn't work on the staging.
    Alex
    Aug 22, 2019 @ 07:01
    Ronald Barendse
    The ImageProcessor package may be updated by Umbraco, but if the same version works locally, but not on the staging environment, it's probably another issue: https://github.com/JimBobSquarePants/ImageProcessor/issues/747.
    So double check whether the PostProcessor packge is installed, remove/uninstall it and check whether it works on staging.
