[SOLVED] Umbraco 7.3.x intellisense & Co: intellisense don't work if project built on VS2013 and passed to VS2015
I started a project under Vs2013 with U7.3.3 and install Umbraco via Nuget.
Under Vs2013 it is all ok: intellisense, etc...
I pass the project under Vs2015...oppssss...intellisense don't work anymore under views and I've a not real error on views that there is not a reference to MVC dll, but I've the reference.
Error:
CS0234 C# The type or namespace name MVC does not exist in the
namespace 'Microsoft.AspNet' #are you missing an assembly reference?#
Do you confirm that is not possible to migrate from Vs2013 to Vs2015? How solve the problem under Vs2015?
So I reopened the project with Vs2013 and it's all ok.
I found the trouble...I try to update Umbraco from 7.3.3 to 7.3.4 via Nuget.
Intellisense start to work...but I've always the dll error and if I open a view this is underline with red line.
Conflict assembly "System.Web.Razor, Culture=neutral, PublicK 1>
eyToken=31bf3856ad364e35" dalla versione "2.0.0.0" [C:\Program Files
(x86)\Microsoft ASP.NET\ASP.NET Web
Pages\v2.0\Assemblies\System.Web.Razor.dll] alla versione "3.0.0.0"
I started a project under Vs2013 with U7.3.3 and install Umbraco via Nuget. Under Vs2013 it is all ok: intellisense, etc...
Error:
I found the trouble...I try to update Umbraco from 7.3.3 to 7.3.4 via Nuget. Intellisense start to work...but I've always the dll error and if I open a view this is underline with red line.
Visual Studio give now this warning:
Problem solved:
to
And after intellisense works again...
