  • Software Tester 1 post 21 karma points
    Dec 25, 2013 @ 10:26
    Software Tester
    RTE problems
    I'm new to Umbraco but used others
    Some things regarding RTEs are important to me but do not seem to work
    1) Bold doesn't show up after publishing
    2) Color picker doesn't work (even after adding a command it doesn't show up)
    3) While copying texts from MSWord (RTF or DOC file) colors are not visible in RTE
    4) While copying texts from MSWord (RTF or DOC file) a text on a new line (after crlf) appears too far underneath the preceeding text
  • nojaf 91 posts 300 karma points
    Dec 26, 2013 @ 09:52
    nojaf
    1) Does your Css overrule bold? Did you apply any css for the tags? 2) No idea 3 & 4)I also have encountered problems with copy pasting from Word. Not sure if it's fully supported.
