Updatepanel in mvc how to get content with a ajax call
Hello umbraco users I need help with something and hope you can help. I want to get content async so the hole page dosent refresh.
I have listed some news and now I want to show the content of the news on the same page maybe with a ajax call and some javascript to fade it in but im not sure where to start, maybe you can just point me in a direction. Im pretty new to umbraco and mvc I normaly just used the updatepanel in the webforms to achieve this.
You should probably first check out the jquery library and it's AJAX functions if you aren't familiar with that. You can use that to make a call to a URL in JavaScript to retrieve either some HTML or JSON that you can then format to display. The URL can be a surface controller set to return a partial view or JSON result, or you could look at the Umbraco Web API controller to return your data.
After the small modifications, my code is very similar to yours. Ajax returns a success response but the controller breakpoint is never hit and so no email is ever sent
I am on 6.1.6 but the code is the same. Any ideas?
Here is my code:
Controller:
public class QuickContactController : SurfaceController
public ActionResult Index()
return PartialView("~/Views/Partials/mes-mini-contact.cshtml", new QuickContactModel());
[HttpPost]
public ActionResult MESQuickContactPost(Models.QuickContactModel model)
string smtp = "internalopenrelay.xxxxx.com";
Document cSettings = new Document(1303);
string from = cSettings.getProperty("fromAddress").Value.ToString();
if (!ModelState.IsValid)
//return CurrentUmbracoPage();
return Json(new { sucess = false });
string _name = model.Name;
string _email = model.Email;
string _messsage = model.Message;
SmtpClient SMTPClient = new SmtpClient(smtp);
MailAddress FromAddress = new MailAddress(from);
MailAddress ToAddress = new MailAddress("me@emailaddress.com");
MailMessage Message = new MailMessage(FromAddress, ToAddress);
Message.Body = string.Format("New message from: {0}<br>Email Address: {1}<p>{2}</p>", _name, _email, _messsage);
Message.Subject = "New MES Quick Contact Message";
Message.IsBodyHtml = true; ;
try
SMTPClient.Send(Message);
catch (Exception)
throw;
SMTPClient.Dispose();
//return RedirectToCurrentUmbracoPage();
return Json(new { success = true });
Model:
public class QuickContactModel
[Required]
public string Name { get; set; }
[Required]
[DataType(DataType.EmailAddress)]
public string Email { get; set; }
[Required]
public string Message { get; set; }
Hi Dan
Here's some documentation links:
http://our.umbraco.org/documentation/Reference/Templating/Mvc/surface-controllers
http://our.umbraco.org/documentation/Reference/WebApi/
Hope that helps get you started.
Andy
Hi Dan!
Here is my contact us form code. Hope it will help you
This is controller
[HttpPost]
public ActionResult ContactUsSubmit(ContactUsModel contactus)
if (ModelState.IsValid == false)
//return PartialView("~/Views/Partials/GiveMeOffer.cshtml", offer);
return Json(new { success = false });
var node = uQuery.GetNode(contactus.NodeId);
var root = uQuery.GetNodesByType("HomePage").FirstOrDefault();
var emailSubject = node.GetProperty("emailSubject").Value;
var fromEmail = root.GetProperty("systemEmail").Value;
var toEmail = node.GetProperty("toEmail").Value;
var emailTemplate = node.GetProperty("emailBody").Value.Replace("##phone##", contactus.CustomerPhone);
emailTemplate = emailTemplate.Replace("##name##", contactus.CustomerEmail);
emailTemplate = emailTemplate.Replace("##email##", contactus.CustomerEmail);
emailTemplate = emailTemplate.Replace("##message##", contactus.CustomerMessage);
var emailUtil = new Utilities();
emailUtil.SendEmail(emailSubject, fromEmail, toEmail, emailTemplate);
//if (contactus.SendCopytoCustomer != null && (bool)offer.SendCopytoCustomer)
// emailUtil.SendEmail(emailSubject, fromEmail, offer.CustomerEmail, emailTemplate);
It is Model
public class ContactUsModel
[Required(ErrorMessage = "Navn må oppgis.")]
public string CustomerName { get; set; }
[Required(ErrorMessage = "Mobil må oppgis.")]
[RegularExpression("^[0-9]+$", ErrorMessage = "Mobil må være nummer.")]
[MinLength(8, ErrorMessage = "Mobil må være 8 tall.")]
[Phone(ErrorMessage = "Mobil må oppgis")]
public string CustomerPhone { get; set; }
[Required(ErrorMessage = "E-post må oppgis.")]
[EmailAddress(ErrorMessage = "Ugyldy e-post.")]
public string CustomerEmail { get; set; }
[Required(ErrorMessage = "Melding må oppgis.")]
[MaxLength(ErrorMessage = "Melding må være under 500.")]
public string CustomerMessage { get; set; }
public int NodeId { get; set; }
Here is partial view
@model client.Models.ContactUsModel
@using (Ajax.BeginForm("ContactUsSubmit", "ContactUsSurface", new AjaxOptions
HttpMethod = "POST",
InsertionMode = InsertionMode.Replace,
UpdateTargetId = "callMeResult",
OnFailure = "ShowError()",
OnSuccess = "ShowSuccess(data)",
<div class="success" style="display: none;">Vi kontakter deg snart!</div>
<div class="errormessage" style="display: none;">Det er noe feil oppset! Prøv senere.</div>
<div class="clearfix step2form">
<div class="step2left contactform">
<div data-error="validationBox" class="textRow">
<div class="rowLabel">
<label for="CustomerName">Navn</label>
@Html.ValidationMessageFor(model => model.CustomerName)
@Html.TextBoxFor(model => model.CustomerName, new { maxLength = 50, autocomplete = "off", placeholder = "Navn",@class ="uniform text" })
<label for="CustomerEmail">E-post</label>
@Html.ValidationMessageFor(model => model.CustomerEmail)
@Html.TextBoxFor(model => model.CustomerEmail, new { maxLength = 50, autocomplete = "off", placeholder = "E-post",@class ="uniform text" })
<label for="CustomerPhone">Mobil</label>
@Html.ValidationMessageFor(model => model.CustomerPhone)
@Html.TextBoxFor(model => model.CustomerPhone, new { maxLength = 50, autocomplete = "off", placeholder = "Mobil",@class ="uniform text" })
<label for="CustomerMessage">Melding</label>
@Html.ValidationMessageFor(model => model.CustomerMessage)
@Html.TextAreaFor(model => model.CustomerMessage, new { placeholder = "Melding",@class ="uniform text" ,cols="38", rows="5" })
<div class="clearfix">
<a class="button2 p19" onclick="Reset();">reset</a>
<input id="callmeSubmit" type="submit" class="button2" value="Send">
@Html.HiddenFor(model => model.NodeId)
<script>
function ShowError() {
$(".errormessage").show();
function ShowSuccess(data) {
if (data.success) {
$(".success").show();
ClearField();
} else {
ShowError();
function Reset() {
ClearField();
$(".success").hide();
$(".errormessage").hide();
function ClearField() {
$(".contactform #CustomerName").val("");
$(".contactform #CustomerPhone").val("");
$(".contactform #CustomerEmail").val("");
$(".contactform #CustomerMessage").val("");
</script>
This is partial view call in a regular view
@Html.Partial("~/Views/Partials/ContactUsForm.cshtml", new Client.Models.ContactUsModel())
But you can improve it if you want to e.g use content servive instead og uquery.
Hope this will help you
Hey Yasir (or anyone!!!).
I followed this tutorial: Ajax Umbraco MVC forms Guide
My code works before the ajax implementation.
Here is my code:
Controller:
Model:
Partial View:
Hi Philip
Can you please submit the form with input type submit rather than using a tag and jquery?
e.g
<inputtype="submit"value="Send"> OR <button type="submit">Send</button>Please let me know if it helps
Yasir
Funny I was just doing that when I saw your reply. Unfortunately, its the same result
are you getting any error or activity in your browser console?
No errors and OnSuccess is triggered and my ShowSuccess js method is executed.
Not that this should matter (but it may) this partial view renders on another partial view as follows:
one error found in your code which is your controller name is QuickContactController in ajax form you are using like
That totally fixed it!
Kudos Yasir!
Thats Great :)
Hey Yasir. I can't mark the threat as answered so hopefully the OP will do it.
Again, thanks mucho for the help.
Sure phillip :)
