Install Digibiz Advanced Media Picker to umbraco 7.0.1 package Help please!!
HI
I am working on MVC umbraco i used umbraco version 7.0.1 and i got task to create sponsor page, the sponsor page will display all the sponsor images and be able to upload multiple file, I have been install Digibiz Advanced Media Picker from my local install to umbraco package back office, the install was successfully but when i went to create data type and select the property editor on the dropdownlist doesn't show the Digibiz Advance Media Picker at all, I have been install FamFamFamIconsPackage also , when i choose the icon all the icons are still the same , they do not change to FamFamFamIconsPackage at all. Please help , I have attached the image below , hank you in advance.
Thank you for your reply,I just found out this morning that this not compatible in V.7 and 7.0.1 . I upload muiltiple images and display image on the template.
It's nice to see that a lot of my packages are used, but probably none of them work on v7. There is a good change that each package in that screenshot isn't compatible with v7. If you are missing features you can create a feature request here: http://issues.umbraco.org/dashboard#newissue=yes
HI
Amp.
A
This package is not compatible with Umbraco 7 - which is why it doesn't show up
What kind of functionality do you need, that is not in the standard media picker / dialog?
you can upload multiple images trough the standard media picker, just click the + and drag files to the dialog (or click the upload button)
I've also created a feature request myself about media: http://issues.umbraco.org/issue/U4-3713
Jeroen
