  • Gordon 21 posts 42 karma points
    Feb 04, 2014 @ 15:57
    Gordon
    Running Umbraco 7 on AWS with multiple instances and load balancing
    I was curious about something. We are looking to use Umbraco on a new development which will be deployed to AWS. Thing is, it will be running on multiple instances with a load-balancer in place.
    Saving the media to S3 storage is the obvious solution when uploading images and media (I noticed there is a provider for this), however, what happens in the case when the users create new Layouts, Templates and views in Umbraco? These get saved down to the local file system meaning the other instances will be out of sync.
    Has anyone else encountered this issue and a way to solve it?
    Thanks in advance
    Gordon
  • Sebastiaan Janssen 5039 posts 15427 karma points MVP admin hq
    Feb 05, 2014 @ 18:24
    Sebastiaan Janssen
    Please make sure to follow the documentation to the letter, load balancing is supported but anything that's a little bit different then the documentation could make it fail:
    http://our.umbraco.org/documentation/Installation/load-balancing
