  • Damiaan 442 posts 1302 karma points MVP 6x c-trib
    Feb 14, 2014 @ 16:39
    Damiaan
    Using IsFirst() in PropertyValueConverter
    I have a PropertyValueConverter for the MNTP. But when I use the .IsFirst() extension method, the IsFirst() checks the original index and not the index of the returned IEnumerable
    The multiNodeTreePicker loads in the nodeId's like this:
    var multiNodeTreePickerContent = umbHelper.TypedContent(nodeIds).Where(x => x != null);
    Afterwards we use thise code to pick up the property:
    var myMntp = Model.Content.GetPropertyValue<IEnumerable<IPublishedContent>>("myMntpProp");
    The first Item in myMntp returns '2' if we call .Position() and false if we call .IsFirst(). Which is corrent if we would look at the backend nodes, but not in the returned IEnumerable list.
    Has someone an idea if (and how) you would need to change the index? Or would this problem be solved if we use the new ValueConverter?
