Problems with 7.0.4 after moving from Azure to SQL Server 2008 R2
I am getting errors any time I attempt to edit anything on the admin site for my website since I moved Umbraco from Azure to SQL Server 2008 R2. Here are a couple of examples:
"Cannot insert the value NULL into column 'id', table 'UmbracoWeb.dbo.cmsContentVersion'; column does not allow nulls. INSERT fails. The statement has been terminated."
"Failed to delete item 1082"
When looking in my logs, I've seen the following errors:
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteScalar()
at StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteScalar() in c:\Code\github\SamSaffron\MiniProfiler\StackExchange.Profiling\Data\ProfiledDbCommand.cs:line 299
at Umbraco.Core.Persistence.PetaPocoCommandExtensions.<>c__DisplayClassa.<ExecuteScalarWithRetry>b__9()
at Umbraco.Core.Persistence.FaultHandling.RetryPolicy.ExecuteAction[TResult](Func`1 func)
at Umbraco.Core.Persistence.Database.Insert(String tableName, String primaryKeyName, Boolean autoIncrement, Object poco)
Found the issue. Apparently I needed to assign identities to the tables when they came over. I only assigned identities to tables with "id" or "pk" as their first column. It _seems_ to have fixed the issue for now. :)
2014-02-20 21:07:12,521 [52] ERROR Umbraco.Core.PluginManager - [Thread 29] Error creating type Umbraco.Core.Models.PublishedContent.PublishedPropertyType+CompatConverter
System.MissingMethodException: No parameterless constructor defined for this object.
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at System.Activator.CreateInstance(Type type)
at Umbraco.Core.PluginManager.CreateInstances[T](IEnumerable`1 types, Boolean throwException)
2014-02-20 21:14:34,916 [52] INFO Umbraco.Core.Persistence.UmbracoDatabase - [Thread 43] at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite)
Any help would be appreciated :)
