  • Dan Evans 631 posts 1018 karma points
    Mar 06, 2014 @ 10:02
    Dan Evans
    loading gif not going in dashboard control
    I have a custom dashboard control which works fine in Umbraco 7 expect that the loader.gif spinning icon remains on the page even after the control has loaded. Is there a way to fix this?
    Dan
    Mar 22, 2014 @ 20:34
    Hi Dan
    Are you still having this issue or did you manage to fix it?
    Otherwise - Have you checked the console of your browsers inspector tool to see if any error messages are being thrown? And did you have a glance at the /app_data/logs file to see if it reveals anything?
  • Arjan Woldring 124 posts 231 karma points
    Mar 24, 2014 @ 22:10
    Arjan Woldring
    I just had the same problem. The icon keeps spinning but there is nothing to load anymore.
    Quick solution: Set the background-color on white (or whatever you prefer) on your div in your custom dashboard html.
    Mar 28, 2014 @ 11:06
    Dan Evans
    I am still having the issue and can't see any errors however the CSS trick works so have gone for that as it's not a deal breaking issue.
