I an trying to make it work correctly an Umbraco 7.0.4 Clean Installation running on 2008 R2 Server. .NET Framework 4.5 is correctly installed and website is running perfectly except for the backend.
No matter what browser i use Chrome, Firefox, Opera, Safari, IE, ... i always get the following error when loading umbraco login page:
Like Charles Afford said I got an error for some time ago, and if I remember correct this was with one of the starter kits, i just re-installed the hole thing with nugget I think that's the easiest way.
Make a new mvc4 project and delete the global file and all files in app_start folder, then run this "Install-Package UmbracoCms" in the Package Manager Console, when you run the installation just take empty instead of a starter kit.
This worked for me.
<add silent="false" initialize="true" sortOrder="1" alias="openTasks" application="translation" title="Tasks assigned to you" iconClosed="icon-folder" iconOpen="icon-folder" type="umbraco.loadOpenTasks, umbraco" />
<add silent="false" initialize="true" sortOrder="2" alias="yourTasks" application="translation" title="Tasks created by you" iconClosed="icon-folder" iconOpen="icon-folder" type="umbraco.loadYourTasks, umbraco" />
Windows 2008 Server R2 SP1 (64 bits). IIS 7.5 .7600.16385 .NET 4.5 Framework and MVC 4 installed. SQL Server 2008 R2 Express Edition (64 bits) - Version 10.50.4000.0 WebsitePanel 2.0.0 for managing domain/websites OS language Spanish (Spain) - Timezone Madrid.
I am doing a manual installation. First at all, i create a new clean domain and website using Websitepanel, with ASP.NET 4.0 (Integrated) dedicated application pool. After that i create a clean 2008 DB and upload all files from "UmbracoCms.7.0.4.zip" downloaded from: http://our.umbraco.org/ReleaseDownload?id=109719
Then i set all read/write permissions following http://our.umbraco.org/wiki/reference/files-and-folders/permissions instructions (also setting Modify/Full control to "Add_Browsers", "Add_Plugins" and "Views"). Finally i go through whole installation process without errors and making a clean installation (no starter kits selected).
I've never used Websitepanel, but have you tried to create a website directly via IIS? It's a long shot, but I had an experience when Plesk messed with permissions and reset them from time to time.
Do you have full access to the server you are trying to install? Are you sure Websitepanel doesn't mess/lock anything on your website?
Have you tried to install on a different machine and if that works copy the website folder on your server?
It's quite weird because I have never had problems with previous Umbraco versions (4.X, 6.X) and Websitepanel. It's just Umbraco 7.
I have full access to the server where i usually deploy Umbraco solutions. I have tried installing Umbraco 7 locally (Windows 7) and then move it to production server but still got same problems.
In this case, the view returns "remainingAuthSeconds":1101.1718203, so Umbraco 7 Backend works as expected but in Windows 2008 R2 production server it returns "SecondsUntilTimeout":1167.5208, instead of "remainningAuthSeconds" value.
Could it be related to System date/time configuration? My server runs spanish OS version by default setting UTC+1 (Madrid).
I have had a lot of trouble with this also (7.0.2 and 7.1) ... spend somehours trouble shooting, and I think I found the issue! If Helicon Ape (http://www.helicontech.com/ape/) is installed at server/IIS, something makes umbraco 7 break... I tried installing / uninstalling three times just make sure...!
I have Helicon Ape installed too. Tried disabling Helicon Ape for Umbraco 7 domain but still got same errors. Did you manage to solve it with Helicon Ape installed?
As Ulrich pointed, seems the problem was related to how Helicon Ape rewrites url and ajax calls.
Version 7.1.1 solves the problem. Based on my personal experience, i find Umbraco 7 a bit unstable yet so i will keep using Umbraco 6 version for a while.
Umbraco 7.0.4 backend not working. Please Help!
/umbraco/backoffice/UmbracoApi/Authentication/IsAuthenticated 404 (Bad Request)
And after login successfully:
The user object is invalid, the remainingAuthSeconds is required. angular.min.js(63)
Login page does not redirect to main control panel after a successfull login. Anyway the backend panel is broken and not working at all.
It's driving me crazy! I have been reading older forum topics commenting this issue but could not found a solution.
Any help?
Ivan
Hi, which enviroment are you running in? Is this a clean install? Have you got the correct permission on your folder? Are you running in IIS?
Charlie.
Hi Charlie,
Thanks for your reply.
My environment:
IIS 7.5 .7600.16385
For testing for testing purposes i have installed Txt Starter Kit.
Folder permissions are correct, i guess. As usual i followed this wiki: http://our.umbraco.org/wiki/reference/files-and-folders/permissions ;
Any ideas?
Hi Ivan Sorry for the late reply
Have you tried re-installing a new Umbraco 7 install with out the starter kit. Those starter kits have had problems in the past :)
Alos in your / site root / config folder
Is the application.config andf trees.config file? and what are the size of those files?
Charlie
Make a new mvc4 project and delete the global file and all files in app_start folder, then run this "Install-Package UmbracoCms" in the Package Manager Console, when you run the installation just take empty instead of a starter kit. This worked for me.
Hi guys!
Thanks for your replys. I will try to install it again following your indications.
Write here again in a while ;-)
Hi again,
Unfortunately, after re-installing Umbraco 7 without any starter kit i got the same problem.
@Charlie:
Those are my applications.config and tress.config:
applications.config
<applications>
<add alias="content" name="Content" icon="traycontent" sortOrder="0" />
<add alias="media" name="Media" icon="traymedia" sortOrder="1" />
<add alias="settings" name="Settings" icon="traysettings" sortOrder="2" />
<add alias="developer" name="Developer" icon="traydeveloper" sortOrder="3" />
<add alias="users" name="Users" icon="trayuser" sortOrder="4" />
<add alias="member" name="Members" icon="traymember" sortOrder="5" />
<add alias="translation" name="Translation" icon="traytranslation" sortOrder="6" />
</applications>
trees.config
<trees>
<!--Content-->
<add initialize="true" sortOrder="0" alias="content" application="content" title="Content" iconClosed="icon-folder" iconOpen="icon-folder" type="Umbraco.Web.Trees.ContentTreeController, umbraco" />
<add initialize="false" sortOrder="0" alias="contentRecycleBin" application="content" title="Recycle Bin" iconClosed="icon-folder" iconOpen="icon-folder" type="umbraco.cms.presentation.Trees.ContentRecycleBin, umbraco" />
<!--Media-->
<add initialize="true" sortOrder="0" alias="media" application="media" title="Media" iconClosed="icon-folder" iconOpen="icon-folder" type="Umbraco.Web.Trees.MediaTreeController, umbraco" />
<add initialize="false" sortOrder="0" alias="mediaRecycleBin" application="media" title="Recycle Bin" iconClosed="icon-folder" iconOpen="icon-folder" type="umbraco.cms.presentation.Trees.MediaRecycleBin, umbraco" />
<!--Settings-->
<add application="settings" alias="stylesheets" title="Stylesheets" type="umbraco.loadStylesheets, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="0" />
<add application="settings" alias="stylesheetProperty" title="Stylesheet Property" type="umbraco.loadStylesheetProperty, umbraco" iconClosed="" iconOpen="" initialize="false" sortOrder="0" />
<add application="settings" alias="templates" title="Templates" type="umbraco.loadTemplates, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="1" />
<add application="settings" alias="partialViews" title="Partial Views" silent="false" initialize="true" iconClosed="icon-folder" iconOpen="icon-folder" type="Umbraco.Web.Trees.PartialViewsTree, umbraco" sortOrder="2" />
<add application="settings" alias="scripts" title="Scripts" type="umbraco.loadScripts, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="3" />
<add application="settings" alias="dictionary" title="Dictionary" type="umbraco.loadDictionary, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="4" />
<add application="settings" alias="languages" title="Languages" type="umbraco.loadLanguages, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="5" />
<add application="settings" alias="mediaTypes" title="Media Types" type="umbraco.loadMediaTypes, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="6" />
<add application="settings" alias="nodeTypes" title="Document Types" type="umbraco.loadNodeTypes, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="7" />
<!--Developer-->
<add initialize="true" sortOrder="0" alias="datatype" application="developer" title="Data Types" iconClosed="icon-folder" iconOpen="icon-folder" type="Umbraco.Web.Trees.DataTypeTreeController, umbraco" />
<add application="developer" alias="macros" title="Macros" type="umbraco.loadMacros, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="2" />
<add application="developer" alias="packager" title="Packages" type="umbraco.loadPackager, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="3" />
<add application="developer" alias="packagerPackages" title="Packager Packages" type="umbraco.loadPackages, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" initialize="false" sortOrder="3" />
<add application="developer" alias="relationTypes" title="Relation Types" type="umbraco.loadRelationTypes, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="4" />
<add application="developer" alias="python" title="Scripting Files" type="umbraco.loadPython, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="4" />
<add application="developer" alias="xslt" title="XSLT Files" type="umbraco.loadXslt, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="5" />
<add application="developer" alias="partialViewMacros" type="Umbraco.Web.Trees.PartialViewMacrosTree, umbraco" silent="false" initialize="true" sortOrder="6" title="Partial View Macro Files" iconClosed="icon-folder" iconOpen="icon-folder" />
<!--Users-->
<add application="users" alias="users" title="Users" type="umbraco.loadUsers, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="0" />
<add application="users" alias="userTypes" title="User Types" type="umbraco.cms.presentation.Trees.UserTypes, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="1" />
<add application="users" alias="userPermissions" title="User Permissions" type="umbraco.cms.presentation.Trees.UserPermissions, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="2" />
<!--Members-->
<add initialize="true" sortOrder="0" alias="member" application="member" title="Members" iconClosed="icon-folder" iconOpen="icon-folder-open" type="Umbraco.Web.Trees.MemberTreeController, umbraco" />
<add application="member" alias="memberGroup" title="Member Groups" type="umbraco.loadMemberGroups, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="1" />
<add application="member" alias="memberType" title="Member Types" type="umbraco.loadMemberTypes, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="2" />
<!--Translation-->
<!-- Custom -->
<!--<add application="myApplication" alias="myTree" title="Me Tree" type="MyNamespace.myTree, MyAssembly"
iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="10" />-->
</trees>
No way. I can't make Umbraco 7.x work on my Windows 2008 R2 SP1 production server.
7.1 beta version won't even begin installation process.
I will keep working with Umbraco 6 and hope Umbraco 7 problems get fixed in the near future.
Can you explain the installation process ?
because mine is working fine.
Hello Dan,
My environment:
IIS 7.5 .7600.16385
Hey Ivan,
Hi Zakhar,
As you suggested, i tried to install Umbraco 7 creating a new website directly via IIS.
Same results ...
Do you have full access to the server you are trying to install? Are you sure Websitepanel doesn't mess/lock anything on your website? Have you tried to install on a different machine and if that works copy the website folder on your server?
Hi Zakhar,
If i call http://mysite.com/umbraco/backoffice/UmbracoApi/Authentication/GetCurrentUser i get the following data:
)]}', {"Email":"jwebgestion@gmail.com","Culture":"en-GB","EmailHash":"5ab892085cdb448c088633adfa9fd1fe","UserType":"admin","SecondsUntilTimeout":1167.5208,"AllowedSections":["content","developer","media","member","settings","users"],"UserId":0,"Name":"admin"}May be malformed?
I still got the same error despite the fact that i have logged in correctly:
Locally, Windows 7 Home Edition, Umbraco 7 works correctly and calling http://localhost/umbraco/backoffice/UmbracoApi/Authentication/GetCurrentUser i get the following data:
)]}', {"email":"jwebgestion@gmail.com","locale":"en-GB","emailHash":"5ab892085cdb448c088633adfa9fd1fe","userType":"admin","remainingAuthSeconds":1101.1718203,"allowedSections":["content","developer","media","member","settings","users"],"id":0,"name":"admin"}In this case, the view returns "remainingAuthSeconds":1101.1718203, so Umbraco 7 Backend works as expected but in Windows 2008 R2 production server it returns "SecondsUntilTimeout":1167.5208, instead of "remainningAuthSeconds" value.
Ulrich Ebsen
Hi Ulrich!
Ivan
Hi Ivan
I tried that also - you have to completely remove Helcon Ape.. and that really sucks.. :-/
Ulrich
Oops! I can't remove Helicon Ape from server (several php sites running). Hope Umbraco team can find a solution soon ;-)
I'm in the excact same situation.. :-/
Same here. Shared web hosting, so I cannot remove anything, using 7.0.4. Also two issues concerning this behaviour have been registered:
I'm deploying a website with Umbraco 7.1.6 to a provider with HELICON APE service.
Unfortunatelly I have the issue.
There are someone with the same experience?
How can I solve it?
