  • Christian Liebe-Harkort 56 posts 104 karma points
    Mar 12, 2014 @ 15:56
    Problem with updating umbraco 7.0.3 to 7.0.4 with nuget
    I created the application from VS 2012 using nuget to install all dependencies. During that time 7.0.3 was the newest vesrion.
    Now I updated to 7.0.4 with
    PM > Update-Package UmbracoCms
    update seemed normal (files were downloaded etc.).
    However, when I run http://mysite/umbraco/ServerVariables to get the umbraco version, I see:
      "application": {
        "assemblyVersion": "1.0.5147.18550",
        "version": "7.0.3"
    Also: changing password fails (This 7.0.4 release is fixing just a single bug: changing a user's password was not possible, from http://our.umbraco.org/contribute/releases/704
    So the update has not worked.
    When I now run
    I get:
    For "UmbracoCms" sind im Projekt "myproject" no Updates available.
    What am I doing wrong?
    christian
    Mar 22, 2014 @ 18:43
    Hi Christian
    Perhaps it's related to this issue? Sebastiaan has written some comments on what to try etc.
    Have you tried to see if it's possible to do an upgrade to 7.1RC?
    Apr 09, 2014 @ 18:21
    HI Jan,
    thanks for your help.
    With version 7.1.1 it worked.
    /Christian
    Apr 09, 2014 @ 19:07
    Hi Christian
    Very happy to hear that - remember to mark the topic as solved :)
    Cheers, Jan
