  • Ben 112 posts 398 karma points
    Mar 31, 2014 @ 20:25
    Ben
    Save and Send For Approval Problem
    I am using Umbraco v7.0.4 and I have found that if a user that has "Send To Publish" permissions and and clicks the green button at the bottom of the editor panel, the document is saved, but no email is sent
    I checked the log and found this:
    2014-03-31 14:11:14,150 [53] ERROR Umbraco.Core.PluginManager - [Thread 65] Error creating type Umbraco.Core.Models.PublishedContent.PublishedPropertyType+CompatConverter
    System.MissingMethodException: No parameterless constructor defined for this object.
       at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
       at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
       at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
       at System.Activator.CreateInstance(Type type, Boolean nonPublic)
       at System.Activator.CreateInstance(Type type)
       at Umbraco.Core.PluginManager.CreateInstances[T](IEnumerable`1 types, Boolean throwException)
    If the same user uses the drop down option after saving the document, the email notification is sent out correctly:
    and the log looks like this:
    2014-03-31 14:11:33,851 [53] INFO  Umbraco.Core.PluginManager - [Thread 54] Starting resolution types of Umbraco.Core.PropertyEditors.IParameterEditor
    2014-03-31 14:11:33,851 [53] INFO  Umbraco.Core.PluginManager - [Thread 54] Completed resolution of types of Umbraco.Core.PropertyEditors.IParameterEditor, found 42 (took 0ms)
    2014-03-31 14:11:33,975 [53] INFO  Umbraco.Core.PluginManager - [Thread 54] Starting resolution types of umbraco.cms.businesslogic.macro.IMacroEngine
    2014-03-31 14:11:33,975 [53] INFO  Umbraco.Core.PluginManager - [Thread 54] Completed resolution of types of umbraco.cms.businesslogic.macro.IMacroEngine, found 2 (took 1ms)
    2014-03-31 14:11:35,369 [53] INFO  Umbraco.Core.PluginManager - [Thread 54] Starting resolution types of umbraco.interfaces.IDataType
    2014-03-31 14:11:35,372 [53] INFO  Umbraco.Core.PluginManager - [Thread 54] Completed resolution of types of umbraco.interfaces.IDataType, found 35 (took 2ms)
    2014-03-31 14:11:35,424 [53] INFO  Umbraco.Core.PluginManager - [Thread 54] Starting resolution types of umbraco.MacroEngines.IRazorDataTypeModel
    2014-03-31 14:11:35,425 [53] INFO  Umbraco.Core.PluginManager - [Thread 54] Completed resolution of types of umbraco.MacroEngines.IRazorDataTypeModel, found 2 (took 1ms)
    Is there anything I can do to get the green button at the bottom of the editor panel to save the document and then send out the email notification?
    Mar 31, 2014 @ 20:50
    Hi Ben
    Have you setup an e-mail to send from in the /config/umbracoSettings.config in the notification area?
    And have you added valid SMTP information in the web.config in the smtp area?
    If you have done that already perhaps it's a bug that should be reported at the issue tracker
    Hope this helps.
    Mar 31, 2014 @ 21:08
    Ben
    Thanks Jan,
    I double checked the email settings in both the web.config and umbracoSettings.config and they both look good (emails are being sent out when the user uses the "Actions" drop down).  I have reported the bug on the issue tracker
