  • Utte 7 posts 27 karma points
    Apr 03, 2014 @ 14:47
    Utte
    Issue with custom controller
    Hi! I'm having troubles creating a custom controller to pass a model to my view. I have followed this http://our.umbraco.org/documentation/Reference/Mvc/custom-controllers but i cant get it to work. At the moment my viewdata and viewbag doesnt pass any data and my "@Model.name" causes an error witch is "'Umbraco.Web.Models.RenderModel' does not contain a definition for 'name'", even though I have the name-attribute in my model. I don't know what to do to make this work, can someone please help me?
    This is my model:
    namespace UmbracoAzureFredrik.Models
         public class Artist
              public string name { get; set; }
    This is my controller:
    namespace UmbracoAzureFredrik.Controllers
        public class VisaController : Umbraco.Web.Mvc.RenderMvcController
            public override ActionResult Index(RenderModel model)
                Artist amodel = new Artist();
                amodel.name = "Felix";
                ViewData["test"] = "test viewdata";
                ViewBag.test = "test viewbag";
                return CurrentTemplate(amodel);
    This is my view:
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<dynamic>
        Layout = "umbLayout.cshtml";
    @ViewBag.test
    @ViewData["test"]
    @Model.name
  • Steve Jones 36 posts 84 karma points
    May 08, 2014 @ 09:38
    Steve Jones
    I have a similar issue with custom model and controllers
    My error seems to return RenderModel to the view and ignore the custom model I passed in
  • Karl Svensson 9 posts 29 karma points
    Oct 22, 2014 @ 12:39
    Karl Svensson
    Hi I am interested in the solution of this issue? Did you get it? Karl
    Oct 22, 2014 @ 22:34
    Utte
    We couldn't make it work so we used javascript instead.
    Oct 22, 2014 @ 22:44
    Steve Jones
    I managed to create a custom model and controller
    In the view I used the approach of using a single doc type per controller and multiple templates, with one for each controller action.
    I really wanted to use a partial view or a macro but currently that's not supported
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Oct 23, 2014 @ 08:32
    Dave Woestenborghs
    You need to change the first line of your view :
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<UmbracoAzureFredrik.Models.Artist>
    But i think this will break your base layout.
    Can I ask why you are using custom view models ?
    Maybe you should have a look at the ZBU Models builder. This generates strongly typede models for your document types :
    https://github.com/zpqrtbnk/Zbu.ModelsBuilder
    And in this video Stéphane explains it in this video : http://uhangout.co.uk/video/NTzb7qQlNzM
    Dave
    Oct 23, 2014 @ 12:23
    Karl Svensson
    I want to connect with EF Models (in existing database) and render data to Umbraco Views.
    Dave, as you explain -sending the models with @inherits UmbracoViewPage<>- fails because the Models must inherit from RenderModel.
    Now I am trying to create a ViewModel class that map this. I will explain it later.
    Oct 23, 2014 @ 23:20
    Steve Jones
    I have been through similar issues and managed to get a working package out there using custom model and controllers with a strongly typed view.
    I was also asked why I am using the Umbraco pipeline and using a custom model but when building an integration package I kind of need to.
    If you want I can did out the source to show you.
    Oct 24, 2014 @ 09:20
    Karl Svensson
    I would appreciate that Steve!
    My web application must interact with data managed in Touchscreen desktop computers, where web environment is not possible.
    I have been trying diferent packages, but all is still a bit too complex for me. It is being difficult to find precise updated information to do simple things...
    Oct 25, 2014 @ 01:00
    Steve Jones
    Consistent documentation has been an issue I agree. I have offered my services to the Umbraco HQ to help build up documentation but I am still waiting for a reply.
    Anyhow, my view and controller snippets are below. My model is a class library which I access using a repository pattern.
    How you access your model I guess is up to you.
    Here's my view, which imherits from Umbraco but I cast it to my model to give me something like a strongly typed view. Because I'm using a custom model and controller and I don't inherit from the RenderModel in my model I have to do this.
    @using Umbraco.Web.Models
    @using LuminousAcuity.Model
        Layout = null;
        List<Organisation> organisations = (List<Organisation>)Model;
        RenderModel m = new RenderModel(Umbraco.Content(UmbracoContext.Current.PageId));
        IPublishedContent p = m.Content.Children.Where(x => x.DocumentTypeAlias == "Organisation").FirstOrDefault();
                    //I have to use a querystring format for the URL because Umbraco doesnt do custom route if you have custom model amd controller
    <h2>@m.Content.GetPropertyValue("title")</h2>
    <section>
        <article>
            <ul>
                    foreach (Organisation org in organisations)
                        <li><a href="@p.Url?taxnumber=@org.TaxNumber">@org.Name</a>
                    </li>
            </ul>
        </article>
    </section>
    Here's my controller, which inherits from Umbraco but I use my own actions and return my custom model. Each action maps to a template and a controller maps to a doctype.
     [PluginController("LuminousAcuity")]
        public class OrganisationController : RenderMvcController
            X509Certificate2 _certificate;
            string _pFXSerialNo;
            string _consumerKey;
            string _userAgent;
            public OrganisationController()
                ConfigHelper configHelper = new ConfigHelper("/");
                _pFXSerialNo = configHelper.GetConfigSetting("PFXCertStoreSerialNo");
                _consumerKey = configHelper.GetConfigSetting("ConsumerKey");
                _userAgent = configHelper.GetConfigSetting("UserAgent");
                _certificate = CertificateHelper.FindBySerialNumber(_pFXSerialNo);
            // GET: /Organisations/
            public ActionResult Organisations()
                using (IOrganisationRepository<Organisation> r = new OrganisationRepository(_userAgent, _consumerKey, _certificate))
                    IEnumerable<Organisation> organisations = r.GetAll();
                    return CurrentTemplate(organisations);
    Oct 26, 2014 @ 13:33
    Karl Svensson
    Thanks, I will test it.
