Richtext editor fails to load sometimes when there is more than 1 inside a doctype
When a node/doctype has more than 1 rich text editor, sometimes they don't load in Umbraco. Upon F5 refresh, it sometimes fixes it but other times not. There is no pattern as to which one works and which one doesn't.
When you have 3 or more it seems to be more prominent.
Has anyone experienced anything similar or have any ideas on how to work around this?
It affects all browsers.
DT
You posted this in the Using Umbraco 7 topic so I assume this is a v7 website? If you have any bugs you can report them here: http://issues.umbraco.org/dashboard#newissue=yes
Jeroen
