  • Onno Sloof 23 posts 43 karma points
    Apr 11, 2014 @ 09:09
    Onno Sloof
    Is their an option to hide certain tabs for specific users?
    I'm looking for a possibility to have the option that certain tabs of document types can be hidden for specific users. So for example the tabs are only visible for admin.
    Can anyone help me with this?
    Onno
    Apr 11, 2014 @ 09:34
    Hi Onno
    Perhaps you can use the Attack monkey tab hider 1.5 for this?
    I don't know if it's compatible with version 7 so it might be a good idea to test it on a fresh installation before installing on the one you're working on.
    If it does not work you could try kindly asking Tim for v7 support on the forum for the package.
    Hope this helps.
