  • Claushingebjerg 939 posts 2574 karma points
    Apr 11, 2014 @ 14:22
    Claushingebjerg
    Fix for imprecision in cropper
    Does anyone have a fix for the bad precision of the cropper in 7?
    This
    Results in this:
    I know there were talks about a small imprecision, but this is massive, and it seems to get worse when zooming.
    Im running 7.1 Cant ssem to find any info indicating if its fixed in 7.1.1...
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 9x admin c-trib
    Apr 11, 2014 @ 14:52
    Wow - that's not an imprecision :)
    Haven't tried using it in frontend yet, but I'll definitely try to see what's going on there...
    /Chriztian
    Apr 11, 2014 @ 14:57
    Claushingebjerg
    Now you're at it, could you check another VERY peculiar behavior.
    Im loosing all crops when setting the site language to danish (da-DK), new crops dont work, neither do existing.
    Setting the locale back to en-US brings the crops back...
    Very weird.
  • Jeavon Leopold 3074 posts 13632 karma points MVP 12x admin c-trib
    Apr 11, 2014 @ 15:35
    Jeavon Leopold
    Hi Claus,
    A few questions for you:
    • Have you upgraded from v7.1beta or RC (this was a bug until v7.1 RTM)
    • Can you check and post the date in the first line of this file \umbraco\Js\umbraco.controllers.js
    • Can you check the file version of /bin/ImageProcessor.dll
    Hopefully one of these will give us a clue.
    Jeavon
    Apr 11, 2014 @ 15:47
    Claushingebjerg
    · Umbraco version 7.1.0-RC assembly: 1.0.5192.30594
    · /*! umbraco - v7.0.0-Beta - 2014-03-20
    · 1.8.6.1
     WTF!!!! Im sure i installed the final 7.1?!?!
    Is updating just a matter of copying all files from the 7.1.1. folder? There's no upgrade guide for 7.1rc to 7.1.1 on http://our.umbraco.org/contribute/releases/711
    Apr 11, 2014 @ 15:54
    Jeavon Leopold
    101
    Well, that's good in a sort of bad way :-)
    Just follow the general upgrade guidelines here I would recommended using a source control or merge tool to merge config files.
    Apr 11, 2014 @ 16:59
    Claushingebjerg
    Yup, that did the trick :)
    Apr 11, 2014 @ 17:22
    Jeavon Leopold
    Awesome, have a good weekend!
    Did that "fix" the locale issue as well, Claus?
    /Chriztian
    Apr 14, 2014 @ 08:08
    Claushingebjerg
    Yup, it fixed both issues.
