Configuration management when deploying to azure using GIT
I just started to use Umbraco, and I have a test/staging/production environment that I deploy as an Azure website using git.
Azure allows me to specify different appSettings and connectionStrings from the management console, but how about the umbraco settings that are different per environment, such as the FileSystemProviders.config?
Is there a way that the path to FileSystemProviders.config file used can be specified in the appSettings, or can I use variables from the appSettings in the FileSystemProviders.config?
What's the recommended approach here?
Wiebe
Is it possible perhaps to configure the FileSystemProviders in code somewhere?
If anyone's interested, I've found this excellent article that helped me set up the configuration management:
http://brian.vallelunga.com/blog/chaining-azure-web-config-transforms-when-deploying-from-source-control
Basically, you can 'chain' web config transformations and pick one based on a setting you can configure in the Azure control panel:
Add this and for example a
Web.Staging.configand aconfig\FileSystemProviders.Staging.configto your project file:The configure this as an 'App Setting' in the Azure control panel:
note that I explicitly had to add a space in front of the
/pto prevent getting a build errorThen I have this in my Web.Staging.config:
And miraculously it worked.
Though I would like to still hear if there's a place that allows me to to Umbraco service configuration in code.
Cheers!
Wiebe
