  • Craig100 1136 posts 2523 karma points c-trib
    Apr 20, 2014 @ 04:06
    Craig100
    Visual Studio Project References
    What are the references you need to add to a project for it to be able to reference an Umbraco mvc content using Model.Content.....etc.? Or is this, or anything like it not possible?
    So far I've tried umbraco.dll, Umbraco.core.dll. cms.dll and businesslogic.dll
    Craig
    Apr 20, 2014 @ 11:14
    Hi Craig
    Have you tried referencing interfaces.dll as well?
    Apr 20, 2014 @ 11:19
    Don't know if it would help to add umbraco.core.models as well according to this early v6 demo by Niels? https://github.com/hartvig/UmbracoV6APITutorial/blob/master/Umbraco.StoreImporterTutorial/ImportProducts.ascx.cs
    Apr 20, 2014 @ 17:17
    Craig100
    Thanks Jan,  Can't see an interfaces.dll anywhere in the Umbraco/bin folder.  Niels' example looks as though it's for web forms. I'm using MVC and want to use strongly typed code if I can. Also I need to be able to traverse content, not use nodeID's as these might change.
    My *real* problem is that I don't know whether people add functionality to Umbraco V7 by adding controllers and models to the Umbraco installation or whether it's done by externally referenced project with its dll dropped into the Umbraco bin folder. I'm just totally stumped on a late project because of this lack of experience/knowledge. There doesn't appear to be any documentation about project set up apart from an out of date one from Sebastiaan on web forms.
    Craig
