But if you do that, do it on a local test install, or remember to take backup first! Or you could try to get in touch with Jeavon on Twitter. He would know if the package will work for v7. It could also be that he knows some similar packages for Umbraco 7.
Setting up default order for nodes
Is there any way how I can have automatic sorting for nodes by date
I know that I can do it manually, but I would prefer to have automatic ordering by date.
Hi Pav
If you are using Partial Views Macros or Partial Views you can order nodes by doing something like this:
This example is for Partial Views Macros:
But if you´re using Partial Views the basic code is the same only thing that change is the @inherits UmbracoTemplatePage
If you´re using old DynamicNodeContext razor let me know and I wouldprovide some code for that.
Hope this helps,
/Dennis
Hi Pav,
Or did you mean in the nodes in backoffice of Umbraco?
/Dennis
Sorry, I have not forget to post that:
Yest I want it in "back office".
Hi Pav,
If you´re using Umbraco 7 you could try installing the package http://our.umbraco.org/projects/developer-tools/document-sorter, but as you can see from this post maybe is not suppport v7. You can try it as a long shot, as Tom mentions
http://our.umbraco.org/projects/developer-tools/document-sorter/bugs,-feedback-and-suggestions/49752-U7-Support
Hope this can help you.
/Dennis
