  • 2le 1 post 21 karma points
    May 10, 2014 @ 22:27
    2le
    requesthandler problem, site crash
    Hi Umbracos
    I am having some problems on my site, since I am running several domains on several folders, on same solution, like shown here:
    Main
    - Folder: Domain: mysite.dk
    - Folder: Domain: mysecondsite.dk
    Problem is that I can access the pages from several domains, duplicate content, and so on.
    I have tried the requestHandler as shown her:
    <requestHandler>
        <!-- this will ensure that urls are unique when running with multiple root nodes -->
        <useDomainPrefixes>false</useDomainPrefixes>
        <!-- this will add a trailing slash (/) to urls when in directory url mode -->
        <addTrailingSlash>true</addTrailingSlash>
        <urlReplacing removeDoubleDashes="false" toAscii="false">
            <char org=" ">-</char>
            <char org="&quot;"></char>
            <char org="'"></char>
            <char org="%"></char>
            <char org="."></char>
            <char org=";"></char>
            <char org="/"></char>
            <char org="\"></char>
            <char org=":"></char>
            <char org="#"></char>
            <char org="+">plus</char>
            <char org="*">star</char>
            <char org="&amp;"></char>
            <char org="?"></char>
            <char org="æ">ae</char>
            <char org="ø">oe</char>
            <char org="å">aa</char>
            <char org="ä">ae</char>
            <char org="ö">oe</char>
            <char org="ü">ue</char>
            <char org="ß">ss</char>
            <char org="Ä">ae</char>
            <char org="Ö">oe</char>
            <char org="|">-</char>
            <char org="&lt;"></char>
            <char org="&gt;"></char>
        </urlReplacing>
    </requestHandler>
    1. I have no idea where to put into the webconfig. Which place does it belong to?
    2. When ever I put it into the webconfig, the site crashes with:
    The requested page cannot be accessed because the related configuration data for the page is invalid.
    Any hints?
    May 11, 2014 @ 01:08
    Hi There
    The above configuration should be placed in the /config/umbracoSettings.config file - and you should change the
    Doing this should make it all work. However you should recycle the app pool after altering the umbracoSettings.config file. That can be done simply by touching the web.config file.
    What version of Umbraco are you using btw?
    Hope this helps.
