  • ketan italiya 17 posts 59 karma points
    May 12, 2014 @ 09:19
    ketan italiya
    Need help for razor syntax in U7 Grid Data Type
    I use this code for razor syntax of U7 Grid Data Type,and also i use umbraco's version 7.1 in webmatrix
    ** razor example **
    <div>
        @foreach (var dog in CurrentPage.dogs)
            <div>
                <p>Name - @dog.name </p>
                <p>Description - @Html.Raw(dog.description) </p>
                @if (dog.image != "") {
                    IPublishedContent iconImg = Umbraco.TypedMedia(dog.image.ToString());
                    <img src="@iconImg.Url" />
                @if (dog.trained == "True")
                    <p>This dog is traind.</p>
    but i can't understand with this example what is currentpage.dogs here can you please help me or give me other example that how i use U7 Grid Data Type in my template page.Here my U7 Grid Data Type contain two column (image and description ).
    Thanks in advance.
    May 12, 2014 @ 10:39
    Dennis Aaen
    Hi ketan,
    I haven´t worked with U7 Grid Data Type, but CurrenPage is represents the page that you´re on in the content tree, and the CurrentPage.dogs, represents a property on the page with a alias of dogs.
    The documentation for working with properties, can be found here: http://our.umbraco.org/wiki/how-tos/working-with-document-types
    Documentation about what CurrentPage is in MVC can be found here:  http://our.umbraco.org/documentation/Reference/Mvc/views#Renderingafieldusing@CurrentPage%28dynamically%29
    Hope this can make your understanding more clear.
    /Dennis
    May 12, 2014 @ 11:54
    ketan italiya
    Thanks Dennis for solution i used with this code but i got error.
    @foreach (var grid in @Model.Content.GetProperty("emprepater"))
    <div>
    @if (grid.image != "")
    IPublishedContent dogImage =Umbraco.TypedMedia(grid.image.ToString());
         <img src="@dogImage" />
    <p>Description - @Html.Raw(grid.description) </p>
    I mean when i am typing @Model then i press dot(.) then also fieldname(emprepater) which is created is not accessible.
    Can you give some suggestion or tips here.
    May 12, 2014 @ 12:56
    Dennis Aaen
    Hi ketan,
    The only thing that I can see right now is wrong is that you have a @ in front of Model.Content.GetProperty("emprepater") in the foreach loop, so try something like this.
    @foreach(var grid in Model.Content.GetProperty("emprepater"))
    <div>
    @if(grid.image !="")
    IPublishedContent dogImage = Umbraco.TypedMedia(grid.image.ToString());
    <img src="@dogImage"/>
    <p>Description-@Html.Raw(grid.description)</p>
    div>
    div>
    And your alias of the field that you want to get data from is named emprepater
    Hope this helps,
    /Dennis
    May 12, 2014 @ 13:34
    ketan italiya
    Thanks for solution,with using your code i got this error.
    foreach statement cannot operate on variables of type 'Umbraco.Core.Models.IPublishedProperty' because 'Umbraco.Core.Models.IPublishedProperty' does not contain a public definition for 'GetEnumerator'
    Can you help me for this?
    May 12, 2014 @ 13:50
    Dennis Aaen
    Hi ketan,
    Okay I will try to see if I could help you help out.
    How about something like this:
    <div>
        @foreach (var grid in CurrentPage.emprepater){
            <div>
            @if (grid.image != ""){
    Hope this helps,
    /Dennis
    May 12, 2014 @ 14:04
    ketan italiya
    Thanks for quick reply Dennis this time it's work for me.but there is one small problem is there. Image is not displaying in website.Imagepath is wrong i think can you help me for this problem?
    May 12, 2014 @ 14:28
    Dennis Aaen
    Hi ketan,
    I think that I spotted what you´re missing. You´re missing url where you are printed the image.
    Try this:
    <div>
    <div>
    <img src="@dogImage.Url"/>
    Hope this helps,
    /Dennis
    May 12, 2014 @ 14:36
    ketan italiya
    Excellent Dennis This is completely work for me thanks for your support.I am really grateful of you.
    May 12, 2014 @ 14:37
    Dennis Aaen
    You´re welcome
