I just set up a local development environment using umbraco 7.1.3.
When i try to get a node programatically from code behind like this:
using Node = umbraco.NodeFactory.Node;
var settingsNode = Node.GetCurrent();
It gives me this error when trying to build:
Error246The type or namespace name 'NodeFactory' does not exist in the namespace 'umbraco' (are you missing an assembly reference?)C:\inetpub\wwwroot\...715projectx
I've referenced the following dll's in my Visual Studio project: cms.dll interfaces.dll businesslogic.dll umbraco.dll
I'm not getting any errors while writing the code, so it looks like it finds the stuff, but when building it halts.
Okay, i figured it out after a good nights sleeep. Apparently i created the Visual Studio project using .NET 4.0, while the Umbraco dll's was compiled with 4.5. Updating the project to 4.5 solved it.
NodeFactory namespace issue
Hi all,
Error 246 The type or namespace name 'NodeFactory' does not exist in the namespace 'umbraco' (are you missing an assembly reference?) C:\inetpub\wwwroot\... 7 15 projectx
cms.dll
interfaces.dll
businesslogic.dll
umbraco.dll
Any ideas?
Thanks!
