  • Ian Black 54 posts 230 karma points
    May 27, 2014 @ 23:27
    Ian Black
    Member Picker Problem
    Is anyone else having trouble with the Member Picker not working?
    I'm running v7.1.3 and when I try to add a Member it brings up the menu on the right with all the member nodes from A-Z. However, when I select one, the right menu disapears but no member has been selected.
    If I then try and add again the right hand menu just comes back blank.
    Ian.
  • Peter Lindberg 1 post 21 karma points
    May 30, 2014 @ 08:19
    Peter Lindberg
    I'm having the exact same issue - which is kind of a pain because I have deadline early next week :)
    /Peter
    May 30, 2014 @ 09:13
    Hi guys
    Perhaps it's a bug - Could you try upgrading to 7.1.4 and see if it still gives the same issue? If so then please file a bug report at the issue tracker at http://issues.umbraco.org/issues
    Cheers, Jan
    May 31, 2014 @ 20:22
    Ian Black
    101
    Hi Jan,
    I updated to 7.1.4 but the problem still persisted. However, I then made sure I cleared Chrome's browser cache. Opened dev tools with F12, selected the cog and chose Disable Cache when dev tools is open. I then hit Ctrl + F5 and the problem was gone. It's working now!
    Not sure if the update was needed or if it was just the browser cache in chrome but cheers!
    Thanks, Ian.
    May 31, 2014 @ 21:18
    Hi Ian
    Ah yes, the dreaded caching issue I really should have thought of that and mentioned it to you...glad you managed to get it fixed though :) Remember to mark the post as solved so others can benefit.
    Cheers, Jan
  • John A 20 posts 44 karma points
    Jul 09, 2014 @ 23:09
    John A
    Exact same problem. Exact same solution. Thanks for posting this Ian!
  • AmandaEly 123 posts 379 karma points
    Mar 17, 2015 @ 11:11
    AmandaEly
    I have created a new problem similar to this because I think it is a new issue in 7.2.2 (not exactly the same)
