  • Anders Brohäll 295 posts 561 karma points MVP c-trib
    May 28, 2014 @ 10:45
    Anders Brohäll
    Render PartialView (UmbracoTemplatePage) from Macro (PartialViewMacroPage)?
    Im trying to render a partial view from inside a macro.
    The macro is registered in the back-office, and has one parameter. The macro is supposed to be available from RTE's.
    The macro is based on a partial view, located in ~/Views/MacroPartials, that inherits Umbraco.Web.Macros.PartialViewMacroPage. Tha macro works, and the parameter gets populated as it's supposed.
    In the macros partial, i want to render a partial that i'm already using on the site - from various templates. The Partial inherits Umbraco.Web.Mvc.UmbracoTemplatePage and is rendered with @RenderPage() with three arguments on top of the path and model. However, when i'm including the Partial with RenderPage, i get an error message telling me:
    The model item passed into the dictionary is of type 'Umbraco.Web.Models.PartialViewMacroModel', but this dictionary requires a model item of type 'Umbraco.Web.Models.RenderModel'.
    I guess that's reasonable, but still, i need to render the Partial from the Macro. How would you approach the problem? Can i change the inheritance in the Partial to make it play nice? What would that be?
  • Jeavon Leopold 3074 posts 13632 karma points MVP 12x admin c-trib
    May 28, 2014 @ 11:08
    Jeavon Leopold
    101
    Hi Anders,
    I would have your Partial View expect a model of IPublishedContent instead of RenderModel, then it can be easily used from both a view and a Partial View Macro.
    e.g.
    Partial View:
    @inherits UmbracoViewPage<IPublishedContent>
        var myHomePage = Model.AncestorOrSelf(1);
    Then it can be called from either View or Macro:
    @Html.Partial("MyPartial", Model.Content)
    Jeavon
    May 28, 2014 @ 12:45
    Anders Brohäll
    Got it working passing the params with a ViewDataDictionary.
    For future reference:
    var viewDataDictionary = new ViewDataDictionary
       {"items", items},
       {"count", count},
       {"heading", heading}
    @Html.Partial("~/Views/Partials/FeedItems.cshtml", Model.Content, viewDataDictionary)
    And accessing the params in the partial as follows:
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<IPublishedContent>
       var items = (IEnumerable<IPublishedContent>)ViewData["items"];
       var count = (int)ViewData["count"];
       var heading = (string)ViewData["heading"];
    ... works from both templates and macro partials.
    Thank you for your help!
    May 28, 2014 @ 13:15
    Jeavon Leopold
    Perfect!
