For some reason, a single node in our install is acting weird, giving us the error:
Failed to retrieve data for content id 0000
Sequence contains no matching element
at System.Linq.Enumerable.Single[TSource](IEnumerable`1 source, Func`2 predicate)
at Umbraco.Web.Models.Mapping.TabsAndPropertiesResolver.ResolveCore(IContentBase content)
at AutoMapper.ValueResolver`2.Resolve(ResolutionResult source)
at AutoMapper.DeferredInstantiatedResolver.Resolve(ResolutionResult source)
at AutoMapper.PropertyMap.<ResolveValue>b__6(ResolutionResult current, IValueResolver resolver)
at System.Linq.Enumerable.Aggregate[TSource,TAccumulate](IEnumerable`1 source, TAccumulate seed, Func`3 func)
at AutoMapper.PropertyMap.ResolveValue(ResolutionContext context)
at AutoMapper.Mappers.TypeMapObjectMapperRegistry.PropertyMapMappingStrategy.MapPropertyValue(ResolutionContext context, IMappingEngineRunner mapper, Object mappedObject, PropertyMap propertyMap)
Umbraco version 7.1.1 assembly: 1.0.5211.22376
I have absolutely no idea what caused this, please help.
It happened after messing around with the tabs of one of the document types. I also tried updating to 7.1.3 before, but that messed up one of our packages.
I've used this script in the past to track them down.
--Umbraco Fix – No Document exists with Version
--Posted by spyriadi on August 8, 2011 Leave a comment (16)Go to comments
--Recently I had problems with a site I have created using umbraco. The problem was that for some reason in the version control of the application there were many orphan versions that where visible on the cmsContentVersion table but not on the cmsDocument. You can find those using the query below:
--Can also show the symptom of issues with the ucomponents subtab
SELECT * FROM cmsContentVersion
WHERE
cmsContentVersion.VersionId NOT IN (SELECT VersionId FROM cmsDocument) AND
cmsContentVersion.ContentId IN (SELECT nodeId FROM cmsDocument)
--Deleting those record fixed my problem and the problematic nodes where shown again in both the content tree view and edit view in umbraco CMS. To delete those versions in your database use the code below:
DELETE FROM cmsContentVersion
WHERE
Can you right click on the node and roll back to a previous version. I had this error sometimes in a old 4.7.2 site. And rolling back to a previous version helped me out.
Sorry to hear that. I had this problem with nodes update by a import process. Sometimes when a error occurred during the import I had to rollback several versions and then I got a working page again.
Hmm, Ive tried rolling back but I wasn't able to fix my issue either. I think I'm running into the same problem. I had a site with 7.1.2 and I upgraded to 7.1.4 and everything is working fine except 1 node (my homepage) in my content tree. I'm not sure how to fix it. I also don't really know how to interpert this error message.
UPDATE: I did find that I got this error when I changed a tab name on my 'master' document type to a new name. My homepage document type was under this so it was inheriting from the master. I went back to the master document type and I changed the name back to what it orginally was and now my homepage node is working again. That seems very odd. Is this a bug in umbraco when naming things or maybe just my instance?
This is just really weird because the rest of my pages are under the master document type which were working just fine with the new tab name, it only affected my homepage. Anyone have any ideas?
In case this helps narrow something down, I can replicate this issue on my 7.1.2 instance. The only packages it has is ezSearch and it was a clean install.
Sequence contains not matching element
-Ferdy
Hi Ferdy
Could upgrading to 7.1.3 be an option? Don't know if it will fix it but perhaps worth the try?
Hi Jan,
-Ferdy
Maybe an orphaned node?
--Umbraco Fix – No Document exists with Version --Posted by spyriadi on August 8, 2011 Leave a comment (16)Go to comments --Recently I had problems with a site I have created using umbraco. The problem was that for some reason in the version control of the application there were many orphan versions that where visible on the cmsContentVersion table but not on the cmsDocument. You can find those using the query below: --Can also show the symptom of issues with the ucomponents subtab SELECT * FROM cmsContentVersion WHERE cmsContentVersion.VersionId NOT IN (SELECT VersionId FROM cmsDocument) AND cmsContentVersion.ContentId IN (SELECT nodeId FROM cmsDocument) --Deleting those record fixed my problem and the problematic nodes where shown again in both the content tree view and edit view in umbraco CMS. To delete those versions in your database use the code below: DELETE FROM cmsContentVersion WHERE cmsContentVersion.VersionId NOT IN (SELECT VersionId FROM cmsDocument) AND cmsContentVersion.ContentId IN (SELECT nodeId FROM cmsDocument)Sadly, the query returns nothing when I run it, so I don't think that's the problem.
Does anyone else have any idea as to how to fix this, because it's kinda important that I do.
-Ferdy
Anyone?
-Ferdy
Dave
Dave,
I tried a couple of different versions, but this doesn't work I'm afraid :(
-Ferdy
Never found a good solution for the problem
Dave
