  • Maxim 50 posts 69 karma points
    Jun 09, 2014 @ 16:53
    Maxim
    Small problems
    I still have some small problems. I know why they are caused but yet i don't know how to solve them.
    • Ucommerce installed but no new tool in left colum. This is caused because i have SQL CE. I have to migrate it to sql server. But when i open my site in webmatrix i don't see a database.
    • Cultiv Razor contact form. I can't find where to change the mailfrom. So now you can fill in the contact form but it sends it to something random i guess. I need to change the mailfrom to my email. The cultirazor contact from is written in the old legacy razor, called DynamicNode razor, so i need to make some rewrite to get working with the Umbraco 7.1.3. I use what is called Partial View Macros or views. Somebody who knows how to solve this?
    • Last thing is that when you log in you get redirected to the page with ucommerce.
    I need this done tomorrow evening tho. These are my final problems. I appreciate all help! :)
    Thank you
    Maxim
    Jun 09, 2014 @ 18:47
    Hi Maxim
    Regarding the issue in Webmatrix - Don't you see a database if you go to the "Database" panel in the lower left corner in the editor? there should be an umbraco.sdf - If you click it you should be able to migrate from CE SQL to MSSQL pretty easily.
    Regarding the Cultiv contactform I still have no clue - no chance of making a custom contact form yourself?
    Jun 09, 2014 @ 18:53
    Maxim
    well i really have not enough knowledge to make a contact form :/
    And yes, i clicked on database in the left corner. I clicked on it when i loaded my umbraco site. He shows no database
