I have to press the button to get the save through. Screen does refresh on ctrl-s. Other editors like masterpages and css do work correcty.
Hi there
What browser are you using and what exact version of Umbraco 7 are you running?
7.1.4 on Chrome. Did not test other browsers because other editors respond correctly on ctrl-s. I can see the page refreshing, but there is nothing saved.
Perhaps this should be filed as a bug report on http://issues.umbraco.org if you don't mind? :)
Cheers, Jan
I see it is already posted as a bug multiple times. thanks
Comment author was deleted
im still getting it in umbraco 7.2
its a hack but it works for me. http://denisemdb.com/learn/fixing-keyboard-shortcut-on-scripting-files-umbraco-7/
CTRL-S Does not seem to work in developer scripting files
Hi there
Cheers, Jan
