I have a umbraco website.
I've created a loginstatus box which uses a conditional razor logic to check if someone's logged.it works the way it should,it has redirects to login page when no one's in,and welcomes the person when someone's in BUT there is no logout and I have no idea now,because tried I very much to find a code for it on the net or by testing everything I knew and still no result.
How do I make a logout method or call an existing one (as umbraco has many methods and controls bult-in)
my website is www.engare.info ,in case you wanted to take a look
but it is not English :D
problem using a logout method in umbraco 7
Hi I have a umbraco website. I've created a loginstatus box which uses a conditional razor logic to check if someone's logged.it works the way it should,it has redirects to login page when no one's in,and welcomes the person when someone's in BUT there is no logout and I have no idea now,because tried I very much to find a code for it on the net or by testing everything I knew and still no result. How do I make a logout method or call an existing one (as umbraco has many methods and controls bult-in) my website is www.engare.info ,in case you wanted to take a look but it is not English :D
many thanks Ashkan
