  • Damien Green 72 posts 134 karma points
    Jul 11, 2014 @ 18:06
    Damien Green
    Problems with Multi-Language website using Umbraco 7
    Hi Guys,
    I've been trying to follow the tutorial on Unbraco.Tv for creating a multi-language website. I'm having a few problems becuase it seems a lot has changed between Umbraco 7 and previous versions, and the tutorials no longer seem to apply.
    The specific problems I am having are:
    1. In the tutorial, assigning the languages. There doesn't seem to be an option called Manage Hostnames anymore. I'm presuming it has been replaced with Culture and Hostnames. However, I cannot type in an "*" as suggested into the domain box, it just says invalid character. What do I need to match my language to any domain as suggested in the tutorial?
    2. Adding a Language switcher. I have placed the razer code into my masterpage template exactly as described in the documentation (see below) but the language selector does not appear. All I get is an empty ul in my output html.
    Does anyone have any idea of what I am doing wrong. Are these tutorials going be updated to cover V7 - at the moment I'm struggling with a lot of this because it all seems to be tied to previous versions. I have a feeling my site hierarchy is incorrect but the documentation is vague when it comes to describing what the hierarchy should be.
    @foreach (var lang in CurrentPage.AncestorOrSelf(1).Siblings())
            <li><a href="@lang.Url">@lang.Name</a></li>
    Many thanks,
    Damien
    Jul 11, 2014 @ 19:59
    Damien Green
    I've found someone else who had the same problem:
    http://our.umbraco.org/forum/umbraco-7/using-umbraco-7/47220-Multi-language-setup-on-a-single-domain
    and I've used his code as an example to fix this on my site. What I'd like to know is whether this is a bug V7 or whether the tutorial doesn't applky to V7...?
    Having debugged through the page, the for each loop isn't yielding any results it might be a problem with my site structure. If anyone has an example structure for this type of site it might reveal the answer.
