(plus the proper <> around the img tag) used to work in Version 6 just fine. Now, in Umbraco 7, it doesn't. It's returns empty and gives the server fits.
It's a Upload Datatype with the name of courseLogo. When I look at the documentation for the Upload DataType - ,http://our.umbraco.org/documentation/using-umbraco/backoffice-overview/Property-Editors/Built-in-Property-Editors/Upload it references "umbracoFile" as the name I'm supposed to be using. But how can I do that when I have 2 upload fields on the same page. They both can't be named umbracoFile.
Upload Datatype - How do I do this is in Umbraco 7? - Same code works perfectly fine in 6
@if (Model.Content.GetPropertyValue("courseLogo").ToString().Length > 0){ img src="@Model.Content.GetPropertyValue }
Hi lonehorseend,
To me it looks like that you are trying to print the image from the Upload Datatype, but only if the field is not empty.
You can do it this way:
The HasValue checks that the field is not empty.
Hope this helps, if I have misunderstood your question, don't hesitate to write again,
/Dennis
