  • Terry Clancy 204 posts 944 karma points
    Jul 20, 2014 @ 08:46
    Terry Clancy
    Installing Umbraco 7.1.4 using VS2013 and Nuget
    I am attemtping to install Installing Umbraco 7.1.4 using VS2013 and Nuget and have followed the instructions at
    http://our.umbraco.org/documentation/Installation/install-umbraco-with-nuget
    When I run / debug the site after installaiton, it does not give me the option to dpecifiy a SQL Server database to use.  It seems to install with SQL Server Compact wheather I want it or not.
    Should it give me the option to specifiy a SQL Server database?
    How can I install using Visual Studio 2013 / Nuget in such a way as to use a SQL Server Standard Database please ?
    Also..... after the installation the follwoing folders are not "included" in the project:  bin, Umbraco, Umbraco_Client, App_browsers, obj,  and several others .  Should they be included in the project ? If so is this a bug ?
    Terry Clancy
    PS I spend more time installing Umbraco than using it !!
    Jul 20, 2014 @ 09:26
    Terry Clancy
    Ignore this question - I just found hte customize link on the install page !!
    Terry Clancy
    Jul 23, 2014 @ 07:48
    Sebastiaan Janssen
    The customize button will be highlighted better in the next release. The folders you mention are not included in the vs project on purpose as there is nothing in there that you'd need to edit in visual studio.
