Started out with an empty ASP.NET project in VS2013. Installed umbraco and built my site.
Ive started following some guides for building contact forms.
I have right clicked a folder and gone to create a controller and i cant do it.
Even if a make a folder called controllers and right click it... no option for controller. I know where the option usually is because ive built basic MVC apps.
Cant create a controller in my Umbraco Project
Hi All,
What gives ?:D
Hi James,
Do you have an option to create a class? If so, just use that and inherit your class from SurfaceController or which ever one you want.
Thanks, Dan.
