I have a macro that allow a user to select a person and that person gets rendered in the RTE. So the person is a parameter (content picker) It uses a partial view macro file (razor).
The partial view is really simple for now:
@inherits Umbraco.Web.Macros.PartialViewMacroPage @{ var person = Umbraco.Content(Model.MacroParameters["person"]); } @person.Picture @person.FirstName
This works fine.
I am trying to create another macro which renders all of the people in a certain category. I want this to be able to render in the RTE as well. This time the category is the parameter (content picker).
In this view, I get all of the people then filter by category (excuse the code quality while I try to get this working, I'll clean it up later):
@using Pcm.Web.Code.Helpers @inherits Umbraco.Web.Macros.PartialViewMacroPage @{ var categoryId = Model.MacroParameters["personCategory"]; var people = new List(Umbraco.Content((int)SpecialNode.People).Children); foreach (var person in people) { var categories = "," + person.GetPropertyValue("category") + ","; if (categories.Contains("," + categoryId + ",")) { var umbracoHelper = new UmbracoHelper(UmbracoContext.Current, person); @:THIS NEEDS FIXING FOR WITHIN THE RTE - see PersonTeamCategoryList.cshtml @:@umbracoHelper.RenderMacro("PersonTeam", new { person = person.Id.ToString() }) } } }
This renders fine on the page, but in the RTE I get an error: Error loading Partial View script (file: ~/Views/MacroPartials/PersonTeamCategoryList.cshtml)
In the log, it says:
2014-07-31 14:32:27,424 [61] WARN umbraco.macro - [Thread 64] Error loading Partial View (file: ~/Views/MacroPartials/PersonTeamCategoryList.cshtml). Exception: System.InvalidOperationException: Cannot render a macro when there is no current PublishedContentRequest.
at Umbraco.Web.UmbracoHelper.RenderMacro(String alias, IDictionary`2 parameters)
at ASP._Page_Views_MacroPartials_PersonTeamCategoryList_cshtml.Execute() in c:\dev\Pcm\Pcm.Web\Views\MacroPartials\PersonTeamCategoryList.cshtml:line 23
at System.Web.WebPages.WebPageBase.ExecutePageHierarchy()
at System.Web.Mvc.WebViewPage.ExecutePageHierarchy()
at System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage)
at Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer)
at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult)
at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content)
at umbraco.macro.LoadPartialViewMacro(MacroModel macro)
at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId)
This appears to be because PublishedContentRequest is null when rendered in the RTE.
Nested macro issue in RTE
I'm using Umbraco 7.1.4.
This works fine.
How can I fix this?
TIA
