What do you intend on including within the package? Is it to contain a custom data type? Custom section? Starter kit? There are some guides on Our with regards to creating packages and how to approach them.
I'm not100%sure whatyou mean bycreating a packagefor multi-languagewebsite?Did youcreatea package ofyour contentfrom thedevenvironment,so you can installyour content onyour livesite
There is a package called 'Contour',I don't know if you are aware or not.It has prebuilt forms that makes developers work little easy.It has a multi language forms setup too.Hope this link will help you.
How to Create a package for multi-language website!
Hiii all,
I am Ravindra i am using umbraco 7.1.4.....
I have create a multi language website using "Multi site structure" and i am stuck at creating a package for it..
can anybody help
regards..
Ravindra!
Hi Ravindra,
Thanks, Dan.
Hi Ravindra,
I'm not 100% sure what you mean by creating a package for multi-language website? Did you create a package of your content from the dev environment, so you can install your content on your live site
Or have I misunderstood your question.
Looking forward to hear from you.
/Dennis
Hii Dennis,
I have a multi language site ie i ha three content pages!
when do i need to create a package for each content page?
Thanks& Regards!
Ravindra
Hi Ravindra
Sorry I am not sure, what do you need a package for, or what are you trying to make a package of?
/Dennis
Hi Ravindra,
http://umbraco.com/help-and-support/customer-area/contour-support-and-download.aspx
