  • Axel 68 posts 96 karma points
    Aug 15, 2014 @ 09:27
    Axel
    How load Jquery when not base path
    Hi, i have as custom Control where i load the jquery lib
    that works if i on the base path of the document. but when i go deper folder it won't be load my jquery lib.
    how can i get the curent base path in my custom control?
    for example if i have the root path
    localhost/umbraco
    it works
    but
    localhost/umbraco/folder1/folder2/
    don't work
    Use Umbraco 7.1,Webforms
  • Tom 120 posts 448 karma points
    Aug 15, 2014 @ 10:07
    Tom
    dont you have like a masterpage - couldn't you just load the js files on there?
  • Dan Lister 416 posts 1974 karma points c-trib
    Aug 15, 2014 @ 12:24
    Dan Lister
    Hi Axel,
    Sounds to me like you need to reference your jQuery library as an absolute path. Something like the following. Note the url starting with a forward slash.
    <script type="text/javascript" src="/scripts/jquery.min.js"></script>
    Thanks, Dan.
