Using examine to index a multi node picker to remove the comas.
I'm using Umbraco 7 to index a multi node picker so I can replace the coma separation with spaces.
This is the code I am using but all the default index return null.
using System;
using System.Text;
using System.Xml.Linq;
using Examine;
using umbraco.BusinessLogic;
using UmbracoExamine;
namespace Site.App_Code
public class ExamineEvents : ApplicationBase
public ExamineEvents()
var y = ExamineManager.Instance;
var x = ExamineManager.Instance.IndexProviderCollection["UmbracoExamine.UmbracoContentIndexer"];
var b = ExamineManager.Instance.IndexProviderCollection["ExamineLuceneIndexSets"];
var c = ExamineManager.Instance.IndexProviderCollection["InternalIndexSet"];
ExamineManager.Instance.IndexProviderCollection["ExternalIndexSet"].GatheringNodeData += ExamineEvents_GatheringNodeData;
void ExamineEvents_GatheringNodeData(object sender, IndexingNodeDataEventArgs e)
GatheringNodeDataHandler(e);
private void GatheringNodeDataHandler(IndexingNodeDataEventArgs e)
//grab the current data from the Fields collection
var mntp = e.Fields["sector"];
//let's get rid of those commas!
mntp = mntp.Replace(",", " ");
//now put it back into the Fields so we can pretend nothing happened!
e.Fields["sector"] = mntp;
using System; using System.Text; using System.Xml.Linq; using Examine; using umbraco.BusinessLogic; using UmbracoExamine; namespace Site.App_Code { public class ExamineEvents : ApplicationBase { public ExamineEvents() { var y = ExamineManager.Instance; var x = ExamineManager.Instance.IndexProviderCollection["UmbracoExamine.UmbracoContentIndexer"]; var b = ExamineManager.Instance.IndexProviderCollection["ExamineLuceneIndexSets"]; var c = ExamineManager.Instance.IndexProviderCollection["InternalIndexSet"]; ExamineManager.Instance.IndexProviderCollection["ExternalIndexSet"].GatheringNodeData += ExamineEvents_GatheringNodeData; } void ExamineEvents_GatheringNodeData(object sender, IndexingNodeDataEventArgs e) { GatheringNodeDataHandler(e); } private void GatheringNodeDataHandler(IndexingNodeDataEventArgs e) { //grab the current data from the Fields collection var mntp = e.Fields["sector"]; //let's get rid of those commas! mntp = mntp.Replace(",", " "); //now put it back into the Fields so we can pretend nothing happened! e.Fields["sector"] = mntp; } } }Fixed. I just needed to use ExternalIndexer.
