Ive got a clean 7.1.5 installation and for some reason my Partial View Macros embedded in the RTE arent showing INSIDE the RTE after I save a document. If I view source the macro tags are there but the orange dotted div isnt displayed, or if I check Render in Rich Text Editor, the Partial View markup isnt being renderd. See screengrab
The problem isnt when rendering on the front-end pages, its the back-office RTE not showing the orange dotted div OR the partial view macro markup. IF you see the first picture above you can see the source showing the UMBRACO_MACRO tag is there but its not being displayed in RTE
RTE not showing Macro AFTER saving
My Partial View Macro simply has the following:
My Macro settings are as follows:
How you render you RTE field on template ?
Hi Yakov
Ben
Just tried on 7.1.6 and I'm getting the same issue - Looks like a bug!
Hi Ismael
See this - seems spaces in macro alias is whats causing it:
http://issues.umbraco.org/issue/U4-4942
Ben
