  • lj 81 posts 425 karma points
    Sep 03, 2014 @ 13:23
    lj
    angularjs property editor problem
    Hi All,
    ive created a property editor using angualrjs.
    What i am trying to now do is when the user clicks 'save and publish' make an ajax call (through a service) to a web api. depending on what is returned i will then set the $scope.model.value to a value for umbraco to automagically save it.
    to do this i have hooked into the method $scope.$on("formSubmitting", function (ev, args) {....} in my controller. This is the only way I know of doing this is there any other?
    The problem is that by the time the ajax call returns umbarco has already saved the $scope.model.value value. is there a way of forcing the $scope.$on method to wait on the ajax request returning before saving. If not how would you go about implementing this process.
    thanks
    lj
    Sep 03, 2014 @ 13:27
    Hi lj
    Could you perhaps share your full code? I think it can perhaps speed up things if people can see the context.
    Cheers, Jan
    Sep 03, 2014 @ 13:38
    lj
    hi there,
    here you go.
    controller ----
    angular.module("umbraco").controller("IsApprovedController", function ($scope, isapprovedResource, $routeParams) {
        var confirmationEmail = false;
        if ($scope.model.value.confirmationEmail != '' && $scope.model.value.confirmationEmail == true) {
            confirmationEmail = true;
        if ($scope.model.value.approved != '' && $scope.model.value.approved == true) {
            $scope.model.approved = true;
        else {
            $scope.model.approved = false;
        //$scope.change = function () {
            $scope.model.value = { approved: $scope.model.approved, confirmationEmail: confirmationEmail };
            console.log(confirmationEmail); console.log(' 2');
            if ($scope.model.approved && !confirmationEmail) {
                //user has approved for the first time so send confirmation email and set flag
                isapprovedResource.SendIsApprovedEmail($routeParams.id).then(function (response) {
                    if(response.data == '\"OK\"')
                        console.log(confirmationEmail); console.log(' 1');
                    else {
                        alert("Alert email was not sent please try again!!");
    heres the html-----
    isapprovedResource.SendIsApprovedEmail is a service that returns "OK" as a string.
    basically this saves a json string like {  "approved": false,  "confirmationEmail": false } to the cmsPropertyData table. once the email has been sent confirmationEmail = true and it wont be sent again.
    thanks
    lj
  • Alain 73 posts 520 karma points c-trib
    Sep 27, 2014 @ 10:06
    Alain
    Hi lj,
    I think Umbraco uses angular js validation for forms validation: http://docs.angularjs.org/guide/forms
    Alain
