Multi sites Umbraco 7 - publishing problems (content does not update)
I have four
small websites on a single Umbraco installation (v. 7.1.4) and everything is
working just fine, except for the publishing: when making changes to a page and
publish, the front-end content does not updated. The only way to update it is to do a web.config
touch.
I checked every bit of documentation to ensure that I have everything in
order and I have: each website has its domain name, its own pool etc. and useDomainPrefixes
is set to true.
I have spent hours trying to change different settings, but no
result.
The different websites do not share templates, each has its own (inherited)
document types. They only share a handull of macroscripts (navigation, breadcrumb). The structure is simple as well: Content:
Site 1
Site 2
Site 3
Site 4
Any hint,
idea or suggestion well appreciated. Thanks.
Here is how I solved this problem in three simple steps:
1. IIS: create one site pointing to the root of the Umbraco installation 2. IIS: On the newley created site, add bindings for each website that will be part of the Umbraco (e.g. mysite1.com, mysite2.com and so on) 3. Umbraco: under each site root, set Culture & Hostnames to the right webaddress (e.g. mysite1.com, mysite2.com and so on)
I have four small websites on a single Umbraco installation (v. 7.1.4) and everything is working just fine, except for the publishing: when making changes to a page and publish, the front-end content does not updated. The only way to update it is to do a web.config touch.
I checked every bit of documentation to ensure that I have everything in order and I have: each website has its domain name, its own pool etc. and useDomainPrefixes is set to true.
I have spent hours trying to change different settings, but no result.
The different websites do not share templates, each has its own (inherited) document types. They only share a handull of macroscripts (navigation, breadcrumb).
Content:
Any hint, idea or suggestion well appreciated.
Thanks.
Even I am facing same problem in our live site. Everytime we need to delete umbraco.config file to see changes made in umbraco.
Please suggest.
I too face it on my site www.techtidy.com
It works just fine and no more caching problems.
