Here (Wall) points to my "Home" page document type and in the "Home" template i have may html master stuff (css, design, image, scripts, (blog, Abous Us, Contact Us) links) etc.
Now for example when i browse with my link like "www.abcd.com" it's throwing the error "Page not found. No template exists to render the document at url '/' "
What I need is , when i enter the url on browser it should open my home / index page. Here content (Wall) is my home page.
If you go to the properties of "Wall" what do you see as the property "link to document"? It should be "/". Next step is to check if you an template for wall, so something should be selected for the property "tempate"
If you don't have a template create one under settings/templates and add it as a allowed template for "Wall"-documenttype under settings/documenttypes
The link to document of "wall" is showing "/UmbracoCMSDevelopment/wall". Here "UmbracoCMSDevelopment" is my site / project name in which i have defined everything document type , template, stylesheet, scripts, images , Content etc.
If i run with my IP address like "http://1.1.1.1/UmbracoCMSDevelopment/wall" then my home page is appearing and from there i can navigate through other pages.
I have domain name with me and edit the bindings in IIS as well. Also i have tried with Umbraco back office.
Content (Wall) -> click on "Actions" -> click on "Culture and Hostnames" -> Enter the domain like (dev.abc.co.uk) -> Click on "Save"
Then i , Click on "Actions" -> Click on "Publish" -> select the check box "Publish wall and it's all subpages" -> Click on "Publish"
After all this no luck.
I also don't want my site / project name (UmbracoCMSDevelopment) in URL. Once user click on "http://dev.abc.co.uk" , It should have to open may home page.
Is the umbraco website in another website/visual studio project or do you run it via your local IIS as a virtual application?
Can you post a screenhost of you tree, because I'm wondering what structure you have if wall is not your homepage. If it were your homepage the url should be http://dev.abc.co.uk/UmbracoCMSDevelopment/" at least
See a screenshot of a website of mine, where you can see that the root document has the link "/"
Yes the umbraco website is in another website (DefaultWebSite) in IIS. Using a WebMatrix , i have generated website with Umbraco CMS with site name as (UmbracoCMSDevelopment). So i have made all the changes in this website and then create a website in "DefaultWebSite" in ISS with "UmbracoCMSDevelopment".
Below is my screen shot of Umbraco backoffice content of my "Wall" stuff.
Now as i need to give URL with domain to my client. I have created another site in IIS with name "(CreateAWall)" and edit the "Bindings" with domain name etc and copy all the folders of (UmbracoCMSDevelopment) to this new website (CreateAWall).
Right now both UmbracoCMSDevelopment and CreateAWall both is on my IIS on server.
When i click the "Link to document", it open up this "http://1.1.1.1/UmbracoCMSDevelopment/create-a-wall"
I simply want same thing when i enter URL on browser (dev.abc.co.uk). It should have to open "/create-a-wall" home page.
Do i need to create another new website (with name "dev.abc.co.uk) and point it to my ISS -> Site -> CreateAWall ? As domain (dev.abc.co.uk) assign to this "CreateAWall" site ?
Or
i can assign existing Umbraco Website to any site in IIS ?
I have solved it now. Actually i have copied the content (all folders) of my existing (UmbracoCMSDevelopment) to my "CreateAWall" site.
Then i go to the folder "CreateAWall" and open it with new site in Webmatrix. Run it localy and then refresh the applicaiton in IIS and it's woring with my domain :-)
also it's opening up by default my index page. :-)
how to set default / index page in Content ?
Below is my content sturcture
Wall
As per this my post (http://our.umbraco.org/forum/umbraco-7/using-umbraco-7/56178-how-to-publish-umbraco-Content-on-server?p=0#comment192541) i have published my content on IIS.
Can you please help me here how to set it up ?
Rohan Dave
Hi Ronan.
Hope this helps!
Kind regards,
Garret
Hi Garret
Thanks for your guidance.
Now when i check the Properties of "Wall" and "Link To Document" then it's showing "http://dev.abc.co.uk/UmbracoCMSDevelopment/wall".
Please help me here.
Thanks in advance !
Rohan Dave
Hi Rotan,
Kind regards,
Garret
Hi Garret
Is the structure i have set missing any thing ?
Rohan Dave
Hi Ronan,
Where do you end up if you click the link on the property "Link to document" and do you also have a template for the documentType WallHome
Kind regards,
Garret
Hi Garret
Or
Thanks in advance !
Rohan Dave
Hi Rohan,
I'n not exactly sure what you're tyring to do and my knowlegde of IIS managment is a bit rusty.
But if you want your umbracosite, which is available in a subdirectory of another site, as I understand, to be available on the root of a domain.
I would create a new website in IIS assign the domain to that site and point the directory to the subdirectory (/Createwall) of the other site.
After you've done this, see what the Link to document property is.
Success!
Garret
Hi Garret
Thanks a lot for your help and guidance !
Thanks again !
Rohan
Hi Ronan,
Glad to be of help, you can close the ticket by marking one of the replies as the solution, and also karma is always appreciated:)
Kind regards,
Garret
