Error with SheduledPublishing, underlying connection was closed
Yesterday a Umbraco 7.1.6 website moved from the staging to the production domain. Since this production site started yesterday, every minute I get these two sheduled publishing related messages:
- ERROR Umbraco.Web.Scheduling.KeepAlive - [Thread 44] Error in ping
- ERROR Umbraco.Web.Scheduling.ScheduledPublishing - [Thread 38] An error occurred with the scheduled publishing
Note that the production domain uses SSL/https and IIS url rewrite has been setup to redirect users to https, which works as intended for all users.
I haven't setup content distribution, it's a standalone website.
Has anyone got a clue where I should start looking?
The complete error messages below.
2014-10-02 12:11:08,191 [5] ERROR Umbraco.Web.Scheduling.KeepAlive - [Thread 44] Error in ping
System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a receive. ---> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
--- End of inner exception stack trace ---
at System.Net.PooledStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.Connection.SyncRead(HttpWebRequest request, Boolean userRetrievedStream, Boolean probeRead)
at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadString(Uri address)
2014-10-02 12:39:38,682 [5] ERROR Umbraco.Web.Scheduling.ScheduledPublishing - [Thread 38] An error occurred with the scheduled publishing
at System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request)
at System.Net.WebClient.UploadString(Uri address, String method, String data)
One step closer, the issue appears to have something to do with SSL redirection in IIS, using the rule below, In the web.config umbracoUseSSL is set to true.
Could it be related to this issue? http://issues.umbraco.org/issue/U4-5379 - The weird thing though is that it seems the reported issue should have been fixed in 7.1.6 though...
@Mark, no I've tried that but that didn't solve it. The value of umbracoUseSSL is set to true.
@Jan, if I turn OFF the urlRewrite rule to force HTTPS, all goes well. It seems to be related to the urlRewrite, although this seems a very common scenario to me.
The odd thing though is, that when I use a System.Net.WebClient from my local development machine to connect to this URL, all goes well and I can watch the resonse.
Following the errormessages in the logs, I scanned the the IIS logs and I can't find any requests to the /umbraco/ping.aspx nor the /umbraco/RestServices/ScheduledPublish/Index
Sounds weird indeed - Perhaps you could try to add a comment about it to the issue I linked above? Just to see if some of the much brighter guys who have had a dialogue there may respond?
Could be a bug or because something needs to be setup differently.
I'm having a very similar problem where my logs are being filled every minute with these errors:
2014-10-30 12:20:24,139 [7] ERROR Umbraco.Web.Scheduling.KeepAlive - [Thread 55] Error in ping
System.Net.WebException: The operation has timed out
at Umbraco.Web.Scheduling.KeepAlive.Start(Object sender)
2014-10-30 12:20:54,154 [7] ERROR Umbraco.Web.Scheduling.ScheduledPublishing - [Thread 10] An error occurred with the scheduled publishing
at Umbraco.Web.Scheduling.ScheduledPublishing.Start(ApplicationContext appContext)
I too am running under SSL using rules within IIS but even removing these rules I still receive these errors.
Visiting /umbraco/ping.aspx works but /umbraco/RestServices/ScheduledPublish/Index brings back a 404.
Well, interesting enough, you receive "The operation has timed out", I receive "The underlying connection was closed". That sounds different but may have the same root cause.
I have same issue, that because my VPS, I can open website on the server, maybe because dns problem.
My solution is change dns to 8.8.8.8 or add website domain to host file like: 127.0.0.1 domain.com
2016-10-18 10:57:27,713 [6] ERROR Umbraco.Web.Scheduling.ScheduledPublishing - [Thread 40] An error occurred with the scheduled publishing
at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
at System.Net.WebClient.UploadString(String address, String data)
This stops us from being able to save and publish a page.
Yesterday a Umbraco 7.1.6 website moved from the staging to the production domain. Since this production site started yesterday, every minute I get these two sheduled publishing related messages: - ERROR Umbraco.Web.Scheduling.KeepAlive - [Thread 44] Error in ping - ERROR Umbraco.Web.Scheduling.ScheduledPublishing - [Thread 38] An error occurred with the scheduled publishing
Note that the production domain uses SSL/https and IIS url rewrite has been setup to redirect users to https, which works as intended for all users. I haven't setup content distribution, it's a standalone website.
Has anyone got a clue where I should start looking? The complete error messages below.
2014-10-02 12:11:08,191 [5] ERROR Umbraco.Web.Scheduling.KeepAlive - [Thread 44] Error in ping System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a receive. ---> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.Net.PooledStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.Net.Connection.SyncRead(HttpWebRequest request, Boolean userRetrievedStream, Boolean probeRead) --- End of inner exception stack trace --- at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request) at System.Net.WebClient.DownloadString(Uri address)
2014-10-02 12:39:38,682 [5] ERROR Umbraco.Web.Scheduling.ScheduledPublishing - [Thread 38] An error occurred with the scheduled publishing System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a receive. ---> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.Net.PooledStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.Net.Connection.SyncRead(HttpWebRequest request, Boolean userRetrievedStream, Boolean probeRead) --- End of inner exception stack trace --- at System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request) at System.Net.WebClient.UploadString(Uri address, String method, String data)
We are getting the same scheduled publish error -- did you resolve it by changing the umbracoUseSSL to true? Ours is False right now.
(never mind, replied twice)
Hi Marcelh
2014-10-30 12:20:24,139 [7] ERROR Umbraco.Web.Scheduling.KeepAlive - [Thread 55] Error in ping System.Net.WebException: The operation has timed out at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request) at System.Net.WebClient.DownloadString(Uri address) at Umbraco.Web.Scheduling.KeepAlive.Start(Object sender)
2014-10-30 12:20:54,154 [7] ERROR Umbraco.Web.Scheduling.ScheduledPublishing - [Thread 10] An error occurred with the scheduled publishing System.Net.WebException: The operation has timed out at System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request) at System.Net.WebClient.UploadString(Uri address, String method, String data) at Umbraco.Web.Scheduling.ScheduledPublishing.Start(ApplicationContext appContext)
I too am running under SSL using rules within IIS but even removing these rules I still receive these errors. Visiting /umbraco/ping.aspx works but /umbraco/RestServices/ScheduledPublish/Index brings back a 404.
Hi Ian, that sounds exactly like the same problem. I noticed /umbraco/RestServices/ScheduledPublish/Index responds with a 404 as well.
I haven't solved it yet, but keep us posted if you do.
Seems like I have the same problem - I had SSL settings in place but removed those now. The error
still appears. Also for me /umbraco/RestServices/ScheduledPublish/Index responds with a 404...
did you guys solve this issue? I'm experiencing the same issue and have also a SSL redirect rule in place.
Upgrading to Umbraco 7.1.9 solved it for me.
yup... i upgraded too (7.2.1) and the problem is solved..
i still got this issue on a totally new 7.2.1 and its not even using SSL.
same here. i found a bug report of this problem already. http://issues.umbraco.org/issue/U4-6085
@Rasmus - I have the same problem using 7.2.1 and not even using SSL
Did anyone figure this one out?
I have same issue, that because my VPS, I can open website on the server, maybe because dns problem. My solution is change dns to 8.8.8.8 or add website domain to host file like: 127.0.0.1 domain.com
Hope it help ;)
Did anyone find a solution to this?
Same issue Umbraco 7.4.3
Related Issue
Anyone found a solution?
Running 7.1.5 and SSL
@bo, see if my solution in this thread helps. I am forcing TLS1.2 in the
ApplicationStartingevent of myApplicationEventHandler.is working on a reply...
