  • Richard Kingston 46 posts 69 karma points
    Oct 06, 2014 @ 09:51
    Richard Kingston
    Problem deleting Document Types
    Can anyone help me decipher the log notes below please?
    Trying to delete 3 unused document types from my umbraco install. I had content assigned to them but used the "Change document type" feature to move them over to other ones. Now these old ones won't delete.
    2014-10-06 08:42:30,596 [6] INFO  Umbraco.Core.Persistence.UmbracoDatabase - [Thread 52]    at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
       at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
       at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
       at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
       at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
       at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds)
       at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite)
       at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean asyncWrite)
       at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
       at StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteNonQuery()
       at Umbraco.Core.Persistence.PetaPocoCommandExtensions.<>c__DisplayClass1.<ExecuteNonQueryWithRetry>b__0()
       at Umbraco.Core.Persistence.FaultHandling.RetryPolicy.ExecuteAction[TResult](Func`1 func)
       at Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteNonQueryWithRetry(IDbCommand command, RetryPolicy cmdRetryPolicy, RetryPolicy conRetryPolicy)
       at Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteNonQueryWithRetry(IDbCommand command, RetryPolicy retryPolicy)
       at Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteNonQueryWithRetry(IDbCommand command)
       at Umbraco.Core.Persistence.Database.Execute(String sql, Object[] args)
    2014-10-06 08:48:51,236 [6] INFO  Umbraco.Core.Persistence.UmbracoDatabase - [Thread 52]    at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
    2014-10-06 08:48:55,167 [6] INFO  Umbraco.Core.Persistence.UmbracoDatabase - [Thread 63]    at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
    The logs are of me trying to delete each, one by one straight after each other.
    Rich
    Oct 12, 2014 @ 16:25
    Hi Rich
    Have you had any success figuring this out? If not could you then tell, which exact version of Umbraco you're using? And did the deleted document types contain any content / inherit form other document types etc.? Or are you using 3rd party packages like the "mixins" package etc.
    Also what database are you using?
    Cheers, Jan
