Looping through multinode treepicker and media picker and creating images
Hi everyone. I'm having an issue with looping through images on a page and getting it to display all the images. I have 4 images in a media picker, in a multinode treepicker. I think my loop may be bad? maybe I'm calling something incorrectly? Whichever it is, I am not sure.
foreach (var temp in Umbraco.Content(clientCollection))
Where clientCollection is var clientCollection = clientList; and clientList is var clientList = CurrentPage.clientList.ToString().Split(new string[] { "," },
In Umbraco, if i remove all but one of the items in clientList, so I only have one node of the multinode treepicker, it works just fine and prints out exactly how I want it to. As soon as I add the other clients, I get this error thrown at the start of that loop. Any suggestions?
Exception Details: Microsoft.CSharp.RuntimeBinder.RuntimeBinderException: The call is ambiguous between the following methods or properties: 'Umbraco.Web.UmbracoHelper.Media(params int[])' and 'Umbraco.Web.UmbracoHelper.Media(params string[])'
It's much happier, and getting passed the temp now, but the same issue remains on the <img tag. As a test, I swapped out the temp.clientLogo with id.clientLogo, just to see what it would print out, and it printed that the string does not contain a method called clientLogo, which while makes sense, is a little different.
Hm... Tested the temp.GetPropertValue<int>("clientLogo") And I got
Exception Details: Microsoft.CSharp.RuntimeBinder.RuntimeBinderException: 'Umbraco.Web.Models.PublishedContentBase' does not contain a definition for 'GetPropertValue'
eI made sure to set the var as TypedContent as well. When swapping out the temp.clientLogo tags for the temp.GetPropertyValue... in the image tag, I get the same error. When I leave it as it was, as temp.clientLogo, with the TypedContent in place, I get
Exception Details: Microsoft.CSharp.RuntimeBinder.RuntimeBinderException: 'Umbraco.Web.Models.PublishedContentBase' does not contain a definition for 'clientLogo'
Thanks, Yea usually i would have a model being passed in to the view / partial with the media object already instanced or properties with URL ect ect :)
Hi everyone.
<img src="@Umbraco.Media(temp.clientLogo).Url" alt="@Umbraco.Media(temp.clientLogo).UrlName" />
Try this code :
@{ foreach (var id in clientCollection) { var temp = Umbraco.Content(id); <img src="@Umbraco.Media(temp.clientLogo).Url" alt="@Umbraco.Media(temp.clientLogo).UrlName" /> } }clientCollection is a list of id's. And Umbraco.Content only can take one id.
Dave
Ah, I understand. I'm still getting the same issue, but I was thinking it might have something to do with that.
The error is now on the var temp = Umbraco.Content(id); if that helps.
Is it the same error or something different ?
Same one
Can you try to out put just the id's to see what that gives you :
@{ foreach (var id in clientCollection) { <p>@id</p> } }Dave
Man, this just confuses me even more. I was hoping it wasn't working, but when I tried that, I get all the id's perfectly.
1122
1130
1134
1135
Ah..I found it. Umbraco.Content takes a int parameter if I am correct. This "should" work.
@{ foreach (var id in clientCollection) { var temp = Umbraco.Content(int.Parse(id)); if(temp != null) { <img src="@Umbraco.Media(temp.clientLogo).Url" alt="@Umbraco.Media(temp.clientLogo).UrlName" /> } } }Dave
Try this :
var temp = Umbraco.TypedContent(int.Parse(id));
And then you should try temp.GetPropertValue<int>("clientLogo").
This way you use the strongly typed IPublishedContent model instead of the dynamic model which is hard to debug.
Dave
I'm not sure what's going wrong at this point.
Can you post the entire code of your view ?
Dave
As of now, the view is incredibly long, so I removed most of the </divs> and such,
@inherits UmbracoTemplatePage
@using umbraco.MacroEngines
Layout = "Base.cshtml";
var homePage = CurrentPage.AncestorsOrSelf(1).First();
var clientList = CurrentPage.clientList.ToString().Split(new string[] { "," }, StringSplitOptions.RemoveEmptyEntries);
<script type="text/javascript" src="//ajax.googleapis.com/ajax/libs/jquery/1.8.2/jquery.min.js"></script>
<script type="text/javascript" src="/js/jquery.bxslider.min.js"></script>
<link href="/css/jquery.bxslider.css" rel="stylesheet" />
(useless working divs here, no code at all)
<div class="small-12 large-10 columns logos">
<ul class="small-block-grid-2 medium-block-grid-4 large-block-grid-4">
if(temp != null)
</ul>
Still stuck on this =\ Does anyone have any ideas?
Sure what is the problem with it :)
So if you have a property with media ids
You can use the MediaService to get a object of type IMedia
MediaService mediaService = ApplicationContext.Current.Services.MediaService; var media = mediaService.GetMediaById(your id)
if(media != null) { var url = media.GetValue("umbracoFile"); }
I have not got visual studio open for intellisense but it should be something like that. :).
Let us know if that helps :).
Charlie
Hi Charles,
The media service is not for use in you views as this queries the database and can become a performance bottle neck.
Dave
Hi Brian,
This code works for me assuming that the clientList property is a mediapicker.
@{ string clientList = Model.Content.GetPropertyValue<string>("clientList"); List<int> ids = new List<int>(); if(!string.IsNullOrEmpty(clientList)) { foreach(string id in clientList.Split(new string[] { "," }, StringSplitOptions.RemoveEmptyEntries)) { ids.Add(int.Parse(id)); } } } @if(ids.Any()) { foreach(int id in ids) { IPublishedContent mediaItem = Umbraco.TypedMedia(id); if(mediaItem != null) { string imageSrc = mediaItem.GetPropertyValue<string>("umbracoFile"); <img src="@imageSrc" alt="@mediaItem.Name" /> } } }Dave
Awesome thanks for that Dave.
Re: Media Service.
What is the performance with Umbraco.TypedMedia?
Charlie
