I just put live an umbraco 7.1.7 site. We mthen added the UrlTacker plugin
now the site is coming up with an error and I can't login in the backend either.
The error is below.
I have ftp access to the site so the question is how do I manually remove this package and hopefully get the site running again ?
InfoCaster.Umbraco.UrlTracker.Repositories.UrlTrackerRepository.ReloadForcedRedirectsCache() in c:\Users\kipusoep\Documents\GitHub\UrlTracker\Repositories\UrlTrackerRepository.cs:529
InfoCaster.Umbraco.UrlTracker.UrlTrackerApplicationEventHandler.ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext) in c:\Users\kipusoep\Documents\GitHub\UrlTracker\UrlTrackerApplicationEventHandler.cs:44
Umbraco.Core.EnumerableExtensions.ForEach(IEnumerable`1 items, Action`1 action) +147
Umbraco.Core.CoreBootManager.Complete(Action`1 afterComplete) +115
Umbraco.Web.WebBootManager.Complete(Action`1 afterComplete) +48
Umbraco.Core.UmbracoApplicationBase.StartApplication(Object sender, EventArgs e) +222
[HttpException (0x80004005): Object reference not set to an instance of an object.]
System.Web.HttpApplicationFactory.EnsureAppStartCalledForIntegratedMode(HttpContext context, HttpApplication app) +12600621
System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers) +175
System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context) +304
System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +404
System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +475
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +12617668
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +159
System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +12457285
Hi, I'm the creator of the UrlTracker and it's lucky for you I noticed this post, because it should've been created on Github: https://github.com/kipusoep/UrlTracker/issues
Anyway, just remove the InfoCaster.UrlTracker.* files in your \bin folder.
The error is really weird btw, it means this line has a NullRef: lock (_cacheLock)
While this is the defintion of _cacheLock: static readonly object _cacheLock = new object();
issue with UrlTracker plugin
Hi guys,
The error is below.
lock (_cacheLock)While this is the defintion of
_cacheLock:static readonly object _cacheLock = new object();So I really don't get it...
