Exception when using uBlogsy & uCommentsy & uSync together
Me and my colleague are currently developing a website using Umbraco and packages mentioned in the caption. To keep sources in sync we're using uSync and uSync.ContentEdition. When I would like to setup a site from the ground I'm downloading the sources and uSync files and then make a full import. But when I make import for uSync.ContentEdition I very often get an error like below. Could someone suggest what can be a reason of this error and how to fix it. If more configuration/environment info is need feel free to ping me - I'll provide it.
Description: An unhandled exception occurred during
the execution of the current web request. Please review the stack trace
for more information about the error and where it originated in the
code.
Source Error:
An unhandled exception was generated during the execution of the current
web request. Information regarding the origin and location of the
exception can be identified using the exception stack trace below.
Source Error:
