We created a contact form in MVC pattern. On submit after the user enters all the required fields, the data entries should bemade to wufoo and should be saved in wufoo. As I referred it we have to use REST for this. Any idea to proceed?
You're welcome :) If the reply solved your issue then please mark it as solved so others can go straight to the solution if they face the same challenge.
Submitting entries and saving in wufoo.
Hi All,
Manasa
Hi Manasa
You should be able to use the Wufoo API I believe.
You can read more about it here http://help.wufoo.com/articles/en_US/SurveyMonkeyArticleType/The-Entries-POST-API
I hope this helps.
Thanks Jan
Hi Manasa
Happy coding.
Use the following code snippet to work around with wufoo form API with umbraco in your controller
string url = "https://cssoft.wufoo.com/api/v3/forms/registration-form/entries.json"; // Add your url string APIKey = "3QNW-MXE2-O74M-RUC6"; // Add your API Key string Hashcode = "mfs802r0uokbfd"; // Add your form Hashcode string usernamePassword = APIKey + ":" + Hashcode; // Prepare web request... HttpWebRequest myReq = (HttpWebRequest)WebRequest.Create(url); CredentialCache mycache = new CredentialCache(); mycache.Add(new Uri(url), "Basic", new NetworkCredential(APIKey, Hashcode)); myReq.Credentials = mycache; myReq.Headers.Add("Authorization", "Basic " + Convert.ToBase64String(new ASCIIEncoding().GetBytes(usernamePassword))); ASCIIEncoding encoding = new ASCIIEncoding(); string postData = "Field1=Anshuman&Field3=3216549870&Field4=test@new.com"; // Add your Fields here byte[] data = encoding.GetBytes(postData); myReq.Method = "POST"; myReq.ContentType = "application/x-www-form-urlencoded"; myReq.ContentLength = data.Length; Stream newStream = myReq.GetRequestStream(); // Send the data. newStream.Write(data, 0, data.Length); newStream.Close();is working on a reply...
