  • Tom C 87 posts 222 karma points
    Dec 04, 2014 @ 19:33
    Tom C
    umbraco 7.2 problem with GetCurrentMember
    Just upgraded from 7.1.8 to 7.2.0 release
    Have a bit of code in the OnLoad method of a User Control
    if (HttpContext.Current.User.Identity.IsAuthenticated) {
        var currentMember =umbraco.cms.businesslogic.member.Member.GetCurrentMember();
    This worked fine before but after upgrade the GetCurrentMember returns null ...
    Dec 04, 2014 @ 19:41
    Hi Tom
    When you did the upgrade did you then read and follow the instructions from http://our.umbraco.org/contribute/releases/720?
    It says that
    "Note that the only significant config file change is that the UmbracoMembershipProvider, UsersMembershipProvider and UmbracoRoleProvider have been updated in the web.config."
    Could that be the issue?
    Dec 04, 2014 @ 20:05
    Tom C
    Hi Jan
    thanks for your reply, but that info is between versions 7.0.x and 7.2.0 not 7.1.x and 7.2.0.
    I did merge my web.configs but there is very little difference between 7.1.8 and 7.2.0.
    Dec 04, 2014 @ 21:05
    Hi Tom
    Ah yes, you're right - I misread that totally.
    Might be a good idea to report this on this issue tracker then.
