I have two questions regardingGetCropUrl.
I am maintaining a huge product database in my project which is stored in Redis. These products have images, which are simply stored in the project folder and not as Media items in Umbraco!
GetCropUrl can be called for a string instead of the IPublishedContent, which is what I do for my images here.
Question 1 String.GetCropUrl does generate the correct image, but doesn't append the rnd parameter/hash. What is this parameter for? Cache busting?
Question 2
I really don't want to output image URIs like: /media/products/nike-academy-14-polyesterjacke-9730.jpg?mode=pad&bgcolor=ffffff&quality=75&maxwidth=200&height=320
in my HTML. I want to rewrite this URL so it matches the given parameters and output a "nice URI" instead.
Something like: /media/products/nike-academy-14-polyesterjacke-9730-XXY.jpg where XXY is a short hash which is for the parameters.
Is this possible? Is there a module in Umbraco which can create nices URIs without query strings? And this shouldn't happen manually, as I have a minimum of 5k images in my project.
Question 1 - yes client cache busting, it is a serialisation of the modified date so it onto changes when the content/media/member is updated. So for your static assets it's probably not needed or you could roll your own system.
Question 2 - this doesn't currently exist for ImageProcessor although I'm sure a module could be developed, or your own http module or you could consider presets perhaps...?
ad 1) Alright, than it's useless for these images. I will probably just append the modified date or something like this, so I have my own little cache buster.
ad 2) Sad. But Presets are a great starting point and will reduce these query strings a lot! I will think about an automated solution and see if I can develop something.
Pretty hard to get the Preset working, as ImageProcessor doesn't seem to recognize the presets :/ which I have added in config/imageprocessor/processing.config
And James, thanks for your explanation on the caching. It's true, I have tested it and it works! :)
Ah, the syntax for your presets is wrong. You can see an example here
Presets aren't a plugin, rather they intercept the querystring and replace the key with the replacemant value.
In your case the configuration should begin with the following.
<?xml version="1.0" encoding="utf-8" ?>
<processing preserveExifMetaData="false">
<!-- Presets that allow you to reduce code in your markup.
Note the use of & to escape ampersands. -->
<presets>
<!-- Instructions are imperative so you would apply the bgcolor after the resize. There's also no 'maxwidth'
instruction and the default resize mode is pad. -->
<preset name="productListing" value="width=200&height=320bgcolor=fff&quality=75"/>
</presets>
<!-- List of plugins. -->
<plugins autoloadplugins="true">
I would make sure you have a good look through the documentation for the available methods so you can get he best out of the system. It's a lot to take in but well worth the read :)
It didn't work, but the documentation says I have to install ImageProcessor.Web.Config and now it works perfectly ;)
I am already experimenting with rewriting the URL so I can create the image path with the query string. Hope I can pack this into a (my first) package :)
ImageProcessor/GetCropUrl problems
Hi!
GetCropUrl. I am maintaining a huge product database in my project which is stored in Redis. These products have images, which are simply stored in the project folder and not as Media items in Umbraco!GetCropUrlcan be called for astringinstead of theIPublishedContent, which is what I do for my images here.Question 1
String.GetCropUrldoes generate the correct image, but doesn't append therndparameter/hash. What is this parameter for? Cache busting?Question 2
/media/products/nike-academy-14-polyesterjacke-9730.jpg?mode=pad&bgcolor=ffffff&quality=75&maxwidth=200&height=320in my HTML. I want to rewrite this URL so it matches the given parameters and output a "nice URI" instead.
Something like:
/media/products/nike-academy-14-polyesterjacke-9730-XXY.jpgwhere XXY is a short hash which is for the parameters.Is this possible? Is there a module in Umbraco which can create nices URIs without query strings? And this shouldn't happen manually, as I have a minimum of 5k images in my project.
Hi Tobias,
Hope that's useful?
Jeavon
Hi Jason.
First, thanks for you answer.
That was very useful, yes, thanks :)
ImageProcessor already detects changes in input files so you shouldn't need a cachebuster.
As far as the second part goes... I'm all ears if you can figure something.
Presetworking, as ImageProcessor doesn't seem to recognize the presets :/ which I have added in config/imageprocessor/processing.configAnd James, thanks for your explanation on the caching. It's true, I have tested it and it works! :)
Yeah, I'm quite proud of that feature. :)
Can you post an example of what you have set up in the config and also a sample url?
Also, can you confirm what version of ImageProcessor.Web you are using?
I have tested it with 3.3.1.0 (which was required by the Umbraco NuGet package) and 4.1.3.0.
Example URL:
http://localhost:1380/media/products/nike-trophy-2-trikot-1-4-arm-3719.jpg?preset=productListingConfig in config/imageprocessor/processing.config:
Thank you, James!
ImageProcessor.Web.Configand now it works perfectly ;)I am already experimenting with rewriting the URL so I can create the image path with the query string. Hope I can pack this into a (my first) package :)
Thanks!
Ah right, sorry, I was under the impression you had already installed the config package.
I'm very glad you managed to get it all working. Good luck writing the package! :)
