  • Claushingebjerg 939 posts 2574 karma points
    Dec 09, 2014 @ 16:32
    Claushingebjerg
    Responsive Video using built in embed
    Im using the fitvids javascript to make embedded videos responsive.
    Is there a simple way to wrap a video from the built in embedder in a div, so i can target it with fitvids?
    Either in embeddedmedia.config or tinyMceConfig.config?
    Dec 09, 2014 @ 16:38
    Dave Woestenborghs
    Don't think so. But you can create your own oEmbed provider that wraps the output in a div.
    Here is the source code for the default video embed : https://github.com/umbraco/Umbraco-CMS/blob/7.2.1/src/Umbraco.Web/Media/EmbedProviders/OEmbedVideo.cs
    Just wrap the output in a div. Don't forget to update the embeddedmedia.config
    dave
    Dec 10, 2014 @ 08:42
    Claushingebjerg
    103
    Well, i have the bad excuse of being a front ender, so im going for a client side solution.
    $( ".content iframe" ).wrap( "<div class='videowrapper'></div>" );
    Seems to work fine
  • MrFlo 159 posts 403 karma points
    Apr 25, 2017 @ 12:30
    MrFlo
    2
    I found this while googling so I will add the backend code.
    Create a class in your project:
    using System.Xml;
    using Umbraco.Web.Media.EmbedProviders;
    namespace ClassicCarPassion.EmbedProviders
        public class OEmbedVideo : AbstractOEmbedProvider
            public override string GetMarkup(string url, int maxWidth, int maxHeight)
                string requestUrl = BuildFullUrl(url, maxWidth, maxHeight);
                XmlDocument doc = GetXmlResponse(requestUrl);
                return "<div class=\"videowrapper\">" + GetXmlProperty(doc, "/oembed/html")+"</div>";
    Change the config:
    <!-- Youtube Settings -->
      <provider name="Youtube" type="ClassicCarPassion.EmbedProviders.OEmbedVideo, ClassicCarPassion">
        <urlShemeRegex><![CDATA[youtu(?:\.be|be\.com)/(?:(.*)v(/|=)|(.*/)?)([a-zA-Z0-9-_]+)]]></urlShemeRegex>
        <apiEndpoint><![CDATA[https://www.youtube.com/oembed]]></apiEndpoint>
        <requestParams type="Umbraco.Web.Media.EmbedProviders.Settings.Dictionary, umbraco">
          <param name="iframe">1</param>
          <param name="format">xml</param>
          <param name="scheme">https</param>
        </requestParams>
      </provider>
    You might have to change the setting for all video providers
  • Richard Hamilton 36 posts 158 karma points
    Jul 21, 2020 @ 07:55
    Richard Hamilton
    Where's that config file? Its been a while since I've needed to do this
    Jul 21, 2020 @ 08:28
    Hi Richard
    If your Umbraco instance is v7 then the config file should be located in the "config" folder in the root of your project. If you're using v8 then this config no longer exists. Many configs have been removed so I think you should have a look at using an "embed provider", which has been documented here https://our.umbraco.com/documentation/extending/Embedded-Media-Provider/
    Callum Whyte made a good article for Skrift about some of the differences between Umbraco 7 and 8, which might be nice for you to read if you're on v8 https://skrift.io/issues/who-moved-my-cheese/ :-)
    Hope this helps!
    Aug 03, 2020 @ 13:35
    Richard Hamilton
    Its actually Umbraco 8 so that's why I couldn't find the config file! Thanks for the link :)
  • Travis Schoening 47 posts 173 karma points
    Jun 29, 2017 @ 00:23
    Travis Schoening
    I'm trying to implement this, and I'm getting the error "Could not embed media - please ensure the URL is valid". Anyone try to do the same thing but get that result and figure out how to correctly use it?
    I'm using 7.6.3.
    Thanks!
  • Eric Wilkinson 21 posts 91 karma points
    Oct 15, 2019 @ 13:30
    Eric Wilkinson
    It sounds like your youtube video URL didn't pass the validation that is defined in the urlSchemeRegex.
