  • Rob Watkins 1 post 21 karma points
    Dec 10, 2014 @ 16:36
    Rob Watkins
    Migrating site from asp.net/C# - question regarding querystrings / SQL
    Hi all,
    A client has asked me to migrate a web site I developed using asp.net/C# to a CMS.  I have looked at several solutions and Umbraco seems to be the best.
    I have subscribed to umbraco.tv and am learning the basics from there.
    However, there are a few issues I'd like some advice on.  Here's the first:
    The site currently has a page that accepts a querystring e.g.
    http://notarealsite.com/thepage.aspx?value=marmite
    The codebehind in thepage.aspx then takes the querystring value and passes it to a stored procedure which queries a SQL database.  The results of the query are then used to build the page content.
    (By the way, it's done this way rather than, say, by having a drop-down list of values on thepage.aspx because the example URL above would be sent out in marketing emails)
    Question: Is this something that could feasibly be done in Umbraco?
    ROUGHLY, how would this be done?  I'm not looking to be spoon-fed a solution, I'm happy of course to do the leg work.  I'm just looking for some general guidance.
    Thank you in advance.
